No power to KBC after chip change
  • p1muserfan
    • Apr 2014
    • 184
    I've got no power TO the KBC chip after replacement, nothing at the 5 power-in pins. Backing up a bit, there is nothing at the resistor before the capacitors leading to the power pins either. Do have 3v at bios chip and 3v from power button at KBC though. Also have 3.3 and 5v from TPS51123
  • p1muserfan
    • Apr 2014
    • 184
    Re: No power to KBC after chip change
    Anybody?
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      check if there is a short-circuit
      • khaahk
        • Dec 2013
        • 783
        • Estonia
        You have to look at Q2703 and Q2705. Why did you change the EC first place? With only battery connected the same thing?
        Check the pictures at this page, was the machine with water damage?
        http://notebook1.ru/forma1/viewtopic...=93849&start=0
        • fddizon
          • Sep 2011
          • 555
          • Philippines
          did you remove cmos battery before removing chip?
          • p1muserfan
            • Apr 2014
            • 184
            No Is it trashed?
            • Agent24
              I see dead caps
              • Oct 2007
              • 4979
              • New Zealand
              It might be, I'm not sure. But it's not a good idea to replace things with the power on.
              -David VanHorn
              • p1muserfan
                • Apr 2014
                • 184
                I've got 3v at 2 out the 3 legs of Q2703 and 3v at the drain of 2705. I changed the EC because the only way the board would start previously was to remove and then reinsert the cmos battery, mistakenly thought that would fix the problem. Now would kill to go back in time, lol. No water damage either.
                • hazardus
                  • Apr 2014
                  • 105
                  Remove the cmos battery and short all the pins on EC.
                  • khaahk
                    • Dec 2013
                    • 783
                    • Estonia
                    Double check ec pins for connection or bridges.
                    See if pin 74 on EC is connected to q2705 gate?
                    Try to pull the gate of q2703 to gnd, that should provide 3v to ec.
                    • Ramee
                      • Jul 2014
                      • 218
                      • Israel
                      (khaahk is right) KBC is not sittin well check all pins.
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1488
                        • portugal
                        yes could be not been sitted , chek with a metal pick and pass on all pins , if any move , then resolder again .. i must post a video of how i solder the te KBC's but dont have a good camera and a tripe to do it .
                        • p1muserfan
                          • Apr 2014
                          • 184
                          Removed the chip and when I flipped it over I have a bunch of solder bridges between many of the pins. Not sure how I'm gonna clean them up but will report back when I do and resolder chip
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3608
                            • slovakia
                            prefect video how to solder chips. kbc is soldered by drag soldering from 2:00
                            https://www.youtube.com/watch?v=5uiroWBkdFY
                            • p1muserfan
                              • Apr 2014
                              • 184
                              Probably a no-no, but even with chip removed there is no power on either side of R2771 (p. 27 upper left)
                              • p1muserfan
                                • Apr 2014
                                • 184
                                Nice!!
                                • p1muserfan
                                  • Apr 2014
                                  • 184
                                  Grounding gate of Q2703 did give me 3v to drain and therefore power to the KBC. So what is messed up and causing 3v to go to gate of 2703?
                                  • khaahk
                                    • Dec 2013
                                    • 783
                                    • Estonia
                                    • p1muserfan
                                      • Apr 2014
                                      • 184
                                      Yes, with chip off the board I have continuity between 74 and gate of Q2705
                                      • khaahk
                                        • Dec 2013
                                        • 783
                                        • Estonia
                                        BQ24707 pin 5 and pin 6 voltages? I think that AC_IN# if pulled low by BQ24707 pin 5, should also pull low the KBC_ON# signal through D2703 opening Q2703.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                          03-31-2024, 02:12 PM
                                        • eukal
                                          Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
                                          by eukal
                                          Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
                                          I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
                                          I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
                                          I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
                                          07-01-2023, 01:00 PM
                                          09-06-2024, 05:59 AM
