Board starts, fan spins for 5 seconds, dies
  • p1muserfan
    • Apr 2014
    • 184
    Have a Compal LA-8241P board that won't boot. When I short the power button the fan spins for about 5 seconds then dies. Tried flashing from from the bios chip of an identical board that has no internal video but starts just fine. No help, same issue. Guessing the bios is seeing something it doesn't like and shuts down? Or do I need a dump from a good machine?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Board starts, fan spins for 5 seconds, dies
    Doubt that, unless it sees a high temp.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • p1muserfan
      • Apr 2014
      • 184
      Well, got it going after reading your post. Was gonna remove the heat sink from the chip and check the thermal grease but the chip popped out of the socket, I didn't have the screw that locks the chip in place in the correct locking position. So it boots now, but no image on external screen (only green light on monitor) or internal (vertical lines) so PCH is probably crap. I need to learn and invest in a reball machine, I swear
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • alltvrepairs
        Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
        by alltvrepairs
        I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
        I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
        Any one met this problem in the past?...
        10-08-2025, 07:34 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
