Dell inspiron no display LA-9104P
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 348
    • India
    VAW00 LA-9104P
    board with cpu on board
    This Laptop has no display only beeps.
    after cheking coils found PL700 power is not there.
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: Dell inspiron no display
    How many beeps?
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 348
      • India
      continuesly .its actualy sorry to tell you its not beep a type of tek tek sparking sound comming from speaker.
      every 2-3seconds
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        maybe schematics helps
        Im Back... sort of...
        • abu obaida
          • Dec 2015
          • 7
          • amman
          when i switched on +3valw & +5valw is ok but +3vs & +5vs & susp# voltage on qz8 is less then normal please any one master can solve the problem stub by stub
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            every 2-3seconds
            Dell 3521 tuk tuk sound is definitely bios problem.Flash both 2mb and 4mb bios and it will solve your problem.May need to remove cmos once.
            • abu obaida
              • Dec 2015
              • 7
              • amman
              i .Flash both 2mb and 4mb bios and it will not solve the problem
              • abu obaida
                • Dec 2015
                • 7
                • amman
                • raajkumar
                  • Mar 2015
                  • 354
                  • Srilanka
                  Flash SIO ( KB chip ). It will resolve your problem.
                  • abu obaida
                    • Dec 2015
                    • 7
                    • amman
                    i change SIO and Flash SIO ( KB chip )and change pch will not solve the problem
                    • megatech27
                      • Nov 2021
                      • 8
                      • Algérie
                      VAW00 LA-9104P
                      change Crystal, in boardview (YH2)
                      • bhachi
                        Jkhatri
                        • Jul 2021
                        • 20
                        • india
                        Definitely its BIOS problem
                        flash attached tested BIOS,
                        °v°
                        /(_)\
                        ^ ^ JKhatri​
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          This is not a bios sub-forum and tested ok bios for same model is already there on the forum.
                          • bhachi
                            Jkhatri
                            • Jul 2021
                            • 20
                            • india
                            ok
                            sorry for the noise ... can you please move the post to the appropriate location ?
                            °v°
                            /(_)\
                            ^ ^ JKhatri​
                            • TheQuentincc
                              Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
                              by TheQuentincc
                              I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
                              06-26-2025, 01:44 PM
                            • master3112
                              by master3112
                              07-29-2025, 01:55 PM
                              DELL Inspiron 7586 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                              This specification for the DELL Inspiron 7586 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7586 boardview and 7586 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron...
                              09-06-2024, 07:11 AM
                              DELL Inspiron 3780 Notebook 3000 Specification for Upgrade or Repair
                              This specification for the DELL Inspiron 3780 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3780 boardview and 3780 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3780...
                              09-06-2024, 08:20 AM
                              09-06-2024, 08:58 AM
