External Device Blew USB Bus??
  • LadyFaire
    • Oct 2014
    • 6
    Plugged in a Bluetooth keyboard to charge up, since it didn't come with an AC adapter. I think the flippin' thing blew my USB bus, since my ports no longer work. I KNOW it blew my USB 3.0 hub, because it no longer works at ALL.
    I thought you couldn't blow the bus with an external device??
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: External Device Blew USB Bus??
    Hot-swappable does not mean indestructable.
    • LadyFaire
      • Oct 2014
      • 6
      The company that sold the Bluetooth keyboard claim that it is not possible for it to have blown the bus. All I know is that I plugged it into the hub first - it just needed charging. The hub started flashing and then just died. Stupid me, I plugged it into a direct USB port. Nothing. The hub, the port the hub was plugged into and the second port no longer work at all.
      Any ideas or suggestions??? I cannot afford a new laptop at this time.
        It may have blown the protection fuse on the 5V line for the USB circuit. Do you still get 5VDC on the USB pin 1?
        • LadyFaire
          • Oct 2014
          • 6
          I will have to check that. To be perfectly frank, I cannot figure how to check the voltage on a USB port! I've tried all sorts of ways, but don't get any coherent readings. Clue me in - how do you set the probes for a USB port??
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Set meter to low voltage DC scale, put red probe on pin1 and black probe on pin4.
              Make sure to use very small probes so you will not accidentally short pin 1 to the metal shroud which is ground and shorted out the 5V line.
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                Very good point Bud. As usual.
                • LadyFaire
                  • Oct 2014
                  • 6
                  The probes I have are too thick. Having hubby bring home some smaller ones, and I'll try it then. Appreciate the help!!
                  • pravin6p
                    • Mar 2014
                    • 75
                    • india
                    you can solder a staple pin on the probes . it ll work.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      that's a little how ya 'doin
                      Follow the white rabbit.
                      • khaahk
                        • Dec 2013
                        • 819
                        • Estonia
                        I suggest you take that keyboard to the company that sold it, find the most expensive laptop there and ask them to plug it in...
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8706
                          I've seen a lot of host USB ports, especially cheap ones, have unfused outputs and could cause damage if a shorted USB device is plugged in.
                          Another trick you might want to try to measure voltage of a USB connector:
                          Take a piece of paper and cut it to the width of the USB slot. Draw four, very dark lines with a graphite #1 pencil that line up with the pins on the USB bus. Extend them, and use these graphite tracks to measure the voltage of your port with a high impedance multimeter.
                          The graphite is probably resistive enough to not cause problems if they short (but watch out for flammable paper!) and should make it easy to "plug" into the port.
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3628
                            • slovakia
                            bad battery
                            when its decharged its nearly shorted, so there is high current to charging and blow the fuse.
