Macbook pro 6.2 strange vga problem
  • lefos
    • Nov 2013
    • 321
    • Greece
    Hello everybody,
    Need your help on this one. This one has 2 gpus. One intel and one nvidia gt330m. It randomly produces panic and restarts. On the report it is pointed that the nvidia gpu has problem. I found a 3rd party program for selecting the running gpu. When intel is enabled no panic after a lot of time working. When you select the nvidia one after a while the osx crashes, reboots and has that report pointing into gt330m. The type of the chipset is N11P-GE1-W-A3. Has to anyone here occurred this problem? It has the latest Mavericks OSX. Normally selection of gpus is done automatically through power management and when it is judged.
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: Macbook pro 6.2 strange vga problem
    seems a bad GPU my friend , very common on that models , but in any case , would be good cheking if there is nvidia drivers to update just to see if he can correct the problem , chek nvidias site for update . if nothing happen then consider in replacing GPU or nvrams
    • lefos
      • Nov 2013
      • 321
      • Greece
      Thanks for your reply. My guess is also on the nvidia's gpu but before changing the chipset wanted to know if it is a common issue of that chipset.
      I will change it then and will inform if it worked out.
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        ok
        • lefos
          • Nov 2013
          • 321
          • Greece
          Finally after changing the gpu chipset the macbook works (3 days fully) without problem.
          Thanks.
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • psdavid65
            Macbook Air A1466 820-3437-B Booting Problem
            by psdavid65
            I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
            06-20-2024, 12:27 AM
          • Skrndelj
            Apple Macbook Air M1 A2337 Trackpad problem
            by Skrndelj
            Hello all,
            I am repairing a Macbook A2337 and i have a problem
            The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
            When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
            I inspected the whole board and everything seems fine.
            Can anyone help me as i didn't fiddle with trackpad...
            06-11-2024, 04:26 AM
          • sofles
            Macbook Pro 16" A2141 screen artefacts, kernel panic
            by sofles
            Hi there.
            I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
            I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
            Now situation looks like this, If...
            02-05-2025, 05:05 AM
          • sdogs
            Macbook Air 2020 A2179 820-01958 battery problem?
            by sdogs
            I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port intermittently).
            After a first inspection I could see that the D3302 protection IC was burnt out, so I replaced it but the problem was not solved, it seems like intermittent 5v input.
            I then replaced the two u3200s (CD3217B12ACE) and now I have stable 20 volts and the macbook has turned back on.
            Unfortunately I have a further problem, it works very slowly and the fan runs at maximum and if I disconnect the charger it turns off, it's as if the battery was disconnected.
            02-08-2024, 08:00 AM
