MacBook A1278 only lights with smc reset
  • inspirim
    • May 2013
    • 282
    • Italy
    This notebook is turned on only with smc reset when you disconnect the power cord will not turn on with the power button.
    no LED indicating that the power cord is connected (green)
    no LED charging (orange)
    you have news for this defect.
    thanks to all
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: MacBook A1278 only lights with smc reset
    that means smc chip is not happy with some voltage. no green light, focus on charger circuit. it give green light.
    • Adogabriel100
      Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
      by Adogabriel100
      Hey! This is a A1278 macbook 2011.
      Problem: Not turning on / No green light
      Im using by3200s charger.
      Voltajes:
      PPBUS_G3H = 12.26v
      SMC_RESET_L = 3.3v
      PP3V42_G3H = 3.42v
      U7000 =
      Pin 1 CHGR_AGATE = 0v
      Pin 2 CHRG_DCIN = 19v
      Pin 3 CHRG_ACIN = 4.6v
      Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
      Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
      Pin 12 PP3V42_G3H = 3.42v
      Pin 13 CHRG_RST_L = 3.3V
      Pin 14 SMC_BC_ACOK = 0.8V
      Pin 19 PP5V1_CHRG_VDD = 5.05V
      Pin 20 PP5V1_CHRG_VDDP = 5.03V...
      04-01-2024, 01:02 PM
    • Rezendes
      Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
      by Rezendes
      Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
      I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
      The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
      05-10-2024, 02:18 PM
    • pcbmaniac
      MacBook A1278 (3115) No PPBUS_G3H Issue
      by pcbmaniac
      Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
      I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
      1. U7000 Measurements:
        • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
      2. Resistors:
        • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
      Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
      • If I also decide to replace the SMC, do I need to order it pre-programmed,
      12-02-2024, 04:12 PM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
      Apple MacBook A1278 051-7918 820-2327 Schematic
      M97A MLB Rev C...
      11-01-2024, 06:53 AM
