Macbook a 1181does not store the date and time
  • inspirim
    • May 2013
    • 282
    • Italy
    This notebook does not store the date and time when the power supply is disconnected, the battery is ok, serves extract schema date and time.
    thanks to all
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Macbook a 1181does not store the date and time
    internal mainboard battery is ok ? the 3volt battery...
    ps: ciauz
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      even if internal cmos bat was dead , if main battery have power it shouldn't lost time and hour . try reseting SMC
      • inspirim
        • May 2013
        • 282
        • Italy
        this notebook has no internal battery, memory, time and date is taken from the battery of the notebook, I tried to do a reset smc but to no avail, I have the wiring diagram of this notebook but I can not figure out which is the integrated date and time .
        thanks to all
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          are you sure ?
          https://www.ifixit.com/Guide/MacBook...eplacement/297
          • inspirim
            • May 2013
            • 282
            • Italy
            you are sure, however, I thank you for everything corrected, track interrupted due to water infiltration.
            thanks to all
            • flat-earther
              Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
              by flat-earther
              I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
              To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
              I have opened the camera and I think there is enough room to add something inside to accomplish this:
              The camera is powered by a 3.7V nominal single cell lithium ion battery.
              So I need to connect another battery in...
              06-08-2025, 02:00 AM
            • envym
              by envym
              Hi everyone!
              06-27-2025, 08:54 AM
            • juergenb
              Sophos XG86w Firewall forgets the date and time as well as the DMI environment variables after power cycle
              by juergenb
              I have a small Sophos XG86w firewall here, which is still working so far. But there is a problem with the BIOS and the DMI environment variables.
              The hardware forgets the date and time after a reboot or a power failure.
              The DMI environment variables are also reset to default values.
              I have now tried 2 different batteries (CR2032).
              I reset the DMI vars via an EFI shell and with AMIDEEFI64 (v5.21.0057).
              However, after a reboot or a power cycle, these values are reset again.
              It is an Apollo Lake platform with an Intel...
              10-08-2024, 04:19 AM
            • Flasman90
              Macbook Pro DFU Restore Issues
              by Flasman90
              I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
              - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
              - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
              08-30-2025, 10:27 AM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
