c850 pskcav
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    c850 pskcav
    no charging and not detecting battery, even not working from charged battery
    i made a bios update,
    changed battery and adapter
    still
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    Re: c850 pskcav
    when i insert battery and charge i get the following readings in battery terminals: 1.84v 1.84v 0v 0v 0.24v 3.24v 3.24v
    and when i remove battery: they will 3.24v 3.24v 0v 0v 3.24v 3.24v 3.24v
    • nazrul145
      • Jan 2014
      • 337
      • BD
      Re: c850 pskcav
      when not detecting battery its SIO related problem. First change SIO controller.
      • rievax_60
        • May 2012
        • 897
        • australia
        Re: c850 pskcav
        Are there any shorted rails? I had an L850 with a shorted ceramic cap on the VBAT rail.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • mkdj
          by mkdj
          Mark and model: ASUS X571
          Tests already made:
          - I have removed...
          07-14-2025, 09:16 AM
        • techfreak9356
          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
          by techfreak9356
          09-14-2023, 11:10 PM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • ferah831208
          by ferah831208
          03-18-2025, 01:18 AM
