Weird problem after changing the southbridge on a Acer
  • ytsoc
    • May 2014
    • 67
    • romania
    Laptop came in with no working usb ports. After replacing the ic powering one of the ports(was a dead short) we had power but no comunication on the usb ports.
    Replaced the southbridge and now the usb ports work.
    But now a weird problem has come up: the laptop dies after approx 5 minutes no matter if it's in windows or in bios or whatever it just suddenly shuts down .
    Did anyone else encounter this problem? If it helps i'll post exact models later .
  • hazardus
    • Apr 2014
    • 105
    Re: Weird problem after changing the southbridge on a Acer
    Maybe it sounds stupid but did you put the RTC battery back?
    • ytsoc
      • May 2014
      • 67
      • romania
      wish it was that simple, yes i put it back and it's good(not drained)
      Another thing i failed to mention is that the fan does not work correctly: it stays locked on a certain speed . That speed is different every time the laptop is powered on, as if the cpu temp isn't being read correctly
      • xxxvirus1987xxx
        unlegendary
        • Sep 2014
        • 24
        • philippines
        you can check it by initial check up..touch every components it most run in low temperature..
        2nd check every voltages if thier is a problem....?
        try to reset bios..
        • ytsoc
          • May 2014
          • 67
          • romania
          It's almost like a protection, i doin't think it's a temp issue as the 5 minutes remain constant. If it was a temp problem, the laptop would shut down sooner when powered on the second time.
          I did try flashing a new bios(via programmer), perhaps i should try to flash one from windows too
          • hazardus
            • Apr 2014
            • 105
            Try to reflow the SB but first try to clean out the flux under the chip.
            • ytsoc
              • May 2014
              • 67
              • romania
              why the southbridge?
              I tried another thing: removed bios and the laptop powers on with no image of course.
              The laptop still shuts down after exactly 4:53 minutes, it must be some sort of protection
              • hazardus
                • Apr 2014
                • 105
                Because that's what you changed on the motherboard.
                Now if it's shuts down exactly the same time then it should be the BIOS.
                Try to downgrade it.
                • ytsoc
                  • May 2014
                  • 67
                  • romania
                  maybe i wrote badly: with or without the bios it still shuts down after 5 minutes.
                  To be honest i'm leaning twards the GPU chip
                  • hazardus
                    • Apr 2014
                    • 105
                    I know you wrote that you tried it without the bios but it will cause the same problem as the "bad" bios even if it's on the mobo or it's not.
                    Try to flash an older bios and let's see what happens.
                    • hazardus
                      • Apr 2014
                      • 105
                      Is this an Acer Aspire 5741G with HM67 chipset?
                      • ytsoc
                        • May 2014
                        • 67
                        • romania
                        it's an acer 5742G HM55 southbridge.
                        I tried several bioses both from the internet and from spare boards.
                        On another forum someone said he has the same problem but his laptop had water damage
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Tried another CPU?
                          A working TV? How boring!
                          • ytsoc
                            • May 2014
                            • 67
                            • romania
                            da , nicio schimbare.
                            yes, no change
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1490
                              • portugal
                              hm55 ???time to replace it... its a crap chipset unfortunetly ,and watch out were you will buy your new chip. i had this issue on a 5742ZG ..only after replacing it was ok !
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1490
                                • portugal
                                now i chekedwell,you replaced HM55 ..what temps have you used soldering the chip ? bottom and up heaters?
                                Lenght of soldering process.
                                Cleaned well all pads? no merges on pads?
                                if water damage , was this happening (shutdown) before the replacement chip ? (for what i've understand on your post , it didnt happen )
                                chek if the mosfets for VCC for this USBS ports are getting hot ,when the computer turned on .
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  Since you're in Bucharest, if you're not in a hurry, i can borrow you my own 5472G for voltage measurements and the like. Send a PM if you need it.
                                    09-06-2024, 05:27 AM
                                  • AquaMan Ua
                                    by AquaMan Ua
                                    05-17-2025, 09:40 AM
                                  • ahmarzo
                                    Acer TMX314-51 laptop battery problem
                                    by ahmarzo
                                    I have acer laptop tmx314-51 with part no 6050A3020501.
                                    The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                                    But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                                    I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                                    The schematic is not available...
                                    04-11-2025, 09:14 AM
                                  • fmajbour
                                    Acer Nitro 5 model A515-51 keyboard problem
                                    by fmajbour
                                    I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                    Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                    i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                    I have check the keyboard connector on the mainboard every thing looks ok.
                                    Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                    I need your advice if anyone face...
                                    11-13-2023, 09:50 PM
                                    Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                    This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                    09-07-2024, 05:00 AM
