Acer Aspire 5750 no B+ voltage
  • multiplexer
    • Dec 2012
    • 30
    • italy
    Re: Acer Aspire 5750 no B+ voltage
    correct values
    • ahmetozay
      • Jul 2013
      • 73
      • turkey
      Originally posted by multiplexer
      correct values
      my measurements as follow
      • ahmetozay
        • Jul 2013
        • 73
        • turkey
        correct values
        Better to put this way
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3559
          • slovakia
          pq17 must be shorted or acoff is on.
          have one of these with bad pq17
          • multiplexer
            • Dec 2012
            • 30
            • italy
            Possible faults:
            ACOFF incorrect value
            PQ17 short between the collector and emitter
            PQ14 short between pins 1-2 and 4-5
            • ahmetozay
              • Jul 2013
              • 73
              • turkey
              #26
              No shorts on PQ17 or PQ14. there is only one option left i think and it is ACOFF . I assume ACOFF comes from KBC so do you advice to change it or there is a way to test it.
              PS. if shorted pin 1 and 8 of PQ7 the system works without battery fine if i insert battery and short the pins of PQ7 short occures on Power supply.
              i have not tested with the battery beause battery is empty and i dont have other one
              • multiplexer
                • Dec 2012
                • 30
                • italy
                #27
                Measure the voltage on ACOFF PQ17
                Desolders PQ17 if your laptop is running (no short on 1-8 FP7) program bios U36, U38
                • ahmetozay
                  • Jul 2013
                  • 73
                  • turkey
                  #28
                  ACOFF is 0v
                  removed PQ17 but no start
                  now flashing U36 and U38 then write the result here
                  flashed both kbc and main but the result is same.
                  there is one odd situation when i turn on the power the output of PQ7 rises slowly upto 0.8v and when i turn off the power the output drops down slowly to 0v. i took a video and share the youtube link soon.
                  • multiplexer
                    • Dec 2012
                    • 30
                    • italy
                    #29
                    PR38 fails
                    replace
                    • multiplexer
                      • Dec 2012
                      • 30
                      • italy
                      #30
                      Please attach your schema compare if it is equal to my
                      • ahmetozay
                        • Jul 2013
                        • 73
                        • turkey
                        #31
                        here it is
                        • ahmetozay
                          • Jul 2013
                          • 73
                          • turkey
                          #32
                          Here is the youtube link http://youtu.be/B78hyYI4xUg
                          • ahmetozay
                            • Jul 2013
                            • 73
                            • turkey
                            #33
                            PR38 fails
                            replace
                            removed PR38 and measured 47k as stated in the schema so PR38 is ok
                            • multiplexer
                              • Dec 2012
                              • 30
                              • italy
                              #34
                              My schematic is rev 0.1
                              I confirm check PR38 = 47K ohm
                              Thanks for the schematic
                              • ahmetozay
                                • Jul 2013
                                • 73
                                • turkey
                                #35
                                PR38 is ok 47K ohm measured
                                • multiplexer
                                  • Dec 2012
                                  • 30
                                  • italy
                                  #36
                                  Originally posted by ahmetozay
                                  Thanks for the reply
                                  PQ14
                                  1=0v
                                  2=0v
                                  3=0v
                                  4=0v
                                  5=0v
                                  6=6.1v
                                  Measure the voltages on all the pins of Q8, Q10, Q14
                                  If you confirm these measures failure PQ14. Replace it
                                  • smali
                                    • Sep 2014
                                    • 287
                                    • Pakistan
                                    #37
                                    Have you checked PQ6?
                                    checked the drain and source short.
                                    • polytek
                                      • Dec 2013
                                      • 496
                                      • TUNISIA
                                      #38
                                      looks like ocp problem, Replace with the correct mosfet 4459, to be sure, remove PR14 and mesure again if you find 19V on PQ7 drain, please replace with the same reference;
                                      • smali
                                        • Sep 2014
                                        • 287
                                        • Pakistan
                                        #39
                                        Checked PQ6 if it is short then 19v will comes to PQ7 gate and this FET will be closed and no output voltage to onward circuit so checked and repalced PQ6.
                                        • ahmetozay
                                          • Jul 2013
                                          • 73
                                          • turkey
                                          #40
                                          well already checked and replaced nothing wrong there.i am stuck really.
                                          if i short pin 8 of PQ6 with pin of PQ7 system works without battery. the only reason is there is 0.25 v on the gate pins of PQ6 and PQ7.
                                            ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                            ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 02:30 PM
                                            ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 05:27 AM
                                            ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
