Re: Acer Aspire 5750 no B+ voltage
insyde windows , well its seem charging the battery as it should , as also when charger the blue light will turn on , indicating battery is full ...
well i got a 5750g , with the la-6901p motherboard and i got a weird issue happening .
This one client complain machine is turning on then off . i noticed that it does that but then turn on alone and stay on ..
the main thing i notice is that , if it works only with dc power , or only with battery , turn on and stay on .
if i insert both , then it turn on then off , then it will turn on and give image..
another thing i notice , when i plug dc and battery , and dont turn on , just to see how its charging , well it does start ok , increasing amp consume . when achieve is higher value , then the amp consume stay crazy , drop from 1.5 amp to 0 then 0.8 1,4 1.7 . 0.8 0 etc and thats not usual , cheked main fets , pq 15 pq 16 pq5 pq7 pq6 pq14 and all seem fine , i even replaced just in case the bloody charger isl6251 but still the same .
strange , any opinions?
Check your super i/o controller.
hi, pins of PQ6 and PQ7 shorted and disabled battery. Delivered to customer working only with ac adapter. End of the story. Thanks for all your help
hi, acording the first post (at the moment dont have time to read whole threads) it look like the protection circuit somehow in a fault mode. i would search for a short, ecpecially on charging circuit and standby circuit. if you short b+ to adapter voltage then if the system is working; stanby, EC, bios, cpu and graphics vcore and clockchip is ok, then check usb ports, componentes attached to usb port(web cam, card reader etc.), charging circuit. i'll read whole posts and next time i come back try to help you more. seems like a bad cap.
Reading all the posts some times one must do a blanket repair. Replacing all the
semi conductors in the area in one go,could be tolerances out.
Fix your measurements with the design
You must receiving 19v on pq6 source if not then confirm the channal of replaced mosfet..when you reveived 19v on both souce of pq6&7 and no outputs on pq7 drain so check pq8 (PNP Transistor ) and pq10 (NPN ). And for checking short the collector and emmiter of the PQ10 and ckeck out put voltage on pq7 (drain ) but before you must received 19 volt on both combined sources of pq6&7.
Originally posted by ahmetozay View Postif i apply 19v to the output of PQ7 board works perfect. Very strange!!!
With voltage values as my design
Check PC12, PC7, PR17, PR27
Others can not be broken.Last edited by multiplexer; 09-16-2014, 06:48 AM.
Originally posted by multiplexer View PostCorrect values to detect:
PS. i removed PQ10 and there was no 8v instead same 0.2vLast edited by ahmetozay; 09-16-2014, 06:29 AM.
Originally posted by ahmetozay View PostPQ14
1=0v
2=0v
3=0v
4=0v
5=0v
6=6.1v
If confirmed replace PQ14 (already recommended)
Another test to confirm PQ14 failure:
Unsolder PQ10 and measure the voltage on pin 4 of PQ7 is 8V
Originally posted by atsio View PostReplace the fets of the chargerAttached FilesLast edited by ahmetozay; 09-16-2014, 03:10 AM.
before it was 19v on all pins of PQ6 and 19v on 1-2-3-4 of pins of PQ7 but 1v output. Measured PU1 of pin 8 and it was 0v which means vref is 0v thus i changed PU1 and vref is 2.4v now but there is 0.2v on the gates of PQ6 and PQ7 now.
if i connect 19v from PQ6 to PQ7 output the system works without battery( i canot connect battery because it will short circuit)
So far...
1- changed PU1(vref is 2.4v now)
2- changed PQ6 and PQ7
3- flashed KBC and Main bios
Are you receiving 19v on pin 1(source) of PQ7
Originally posted by ahmetozay View Postthe only reason is there is 0.25 v on the gate pins of PQ6 and PQ7.
https://www.badcaps.net/forum/attach...1&d=1410357719
What are the correct values ?
Originally posted by smali View PostChecked PQ6 if it is short then 19v will comes to PQ7 gate and this FET will be closed and no output voltage to onward circuit so checked and repalced PQ6.
if i short pin 8 of PQ6 with pin of PQ7 system works without battery. the only reason is there is 0.25 v on the gate pins of PQ6 and PQ7.
