Dell xps m140 (pp19L)
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Anybody got schematic for this old laptop dell XPS M140 PP19L. power turns off after 5 seconds. Thanks
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Re: Dell xps m140 (pp19L)
    motherboard code is 48 4C401 011.
    • atsio
      • Oct 2013
      • 819
      • Greece
      • lezsimply
        The Wanderer
        • 657
        • Philippines
        Thank you atsio as always. I need help on reading voltages of charger ic, U6 on page 42 of schem. I'm lost from there.
        Pin no.
        1 -19.60v
        2 -5.43v
        3 -2.39v
        4 -4.22v
        5 -3.06v
        6 -3.27v
        7 -1.72v
        8 -0v
        9 -1.69v
        10 -0v
        11 -2.59v
        12 -0v
        13 -0v
        14 -0v
        15 -0v
        16 -12v
        17 -12v
        18 -12v
        19 -0v
        20 -0v
        21 -5.42v
        22 -19.05v
        23 -19.05v
        24 -19.80v
        25 -19.78v
        26 -19.78v
        27 -9.38v
        28 -19.53v
        Problem power tuns off after 5 secs. 3.3v present on power button. I'm still looking for short. Many many thanks
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          Check the usb ports
          • lezsimply
            The Wanderer
            • 657
            • Philippines
            This laptop was working, before it was kept for 8 months since the owner bought a new one.
            • lezsimply
              The Wanderer
              • 657
              • Philippines
              If laptop turns off after a few seconds does is always mean it has short on board?
              • dj_ricoh
                • 2073
                • uk
                change the bios battery and rewrite the bios.
                I know when there is n channel mosfet on the first line when acin in over 1.5v acok must be low low ( 0v) but i don't know how it works with p channel like you have here
                • xxxvirus1987xxx
                  unlegendary
                  • Sep 2014
                  • 24
                  • philippines
                  dont ignore bad capacitors better to replace it with a new one....
                  also cold solder...
                  • lezsimply
                    The Wanderer
                    • 657
                    • Philippines
                    @ dj
                    rtc battery is good. I don't think I can rewrite bios I don't have 40-pin adapter for that.
                    @virus
                    I'm still looking for shorts. I have resoldered dozens of caps and transistors. Tested most of them and found no short. Used 3 different original adapters. Usb ports are all ok.
                    thanks guys!
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      Check resistance on all coils to ground
                      • andrhouseolly
                        Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                        by andrhouseolly
                        Hi.
                        I kindly ask you to help me solve the problem.
                        Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                        The board turns on, there is no image.
                        Read more. When the power supply is connected, the front panel indicators light up briefly.
                        When you press the power button, the button indicator lights up. The board works
                        there is no image, there is no matrix initialization, there is no image on HDMI.
                        When turned on, the fans do not spin, but when they warm up they start spinning.
                        When you turn off the button, the fans spin up to full speed for a short...
                        05-11-2024, 03:14 PM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • retrorepair2
                        Dell E5470 LA-C631p - Short removed now turns on but no post/display
                        by retrorepair2
                        Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
                        Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...
                        09-25-2025, 07:12 AM
                      • manol278
                        Dell laptop E6440 val91 la-9934p turns off
                        by manol278
                        Hi. I have problem with dell laptop E6440 val91 la-9934p rev.1.
                        I turn on the laptop and it turns off instantly. After 5-6 attempts it turns on normally. I saw that it was burnt PU800, CD3301B Power Controller Chip.
                        If you see in the photo someone tried to do bypass and remove PR831, PR832, PC820, PR838.
                        I will replace CD3301B. I have the schematic but i dont know what are the characteristics of other componets to replace...
                        [Mod. Edit]
                        Schematic -> https://www.badcaps.net/forum/troubl...cs-theory/trou...
                        01-26-2024, 11:50 AM
                      • Kambi13
                        Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
                        by Kambi13
                        Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
                        Not heat related, everything is ok regarding to that.
                        All voltages are present.
                        Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
                        Motherboard is Cedar 13269-1 F3XMC Rev A00...
                        07-12-2024, 06:10 AM
