i've done a lot of smaller bga chip replacments but the pch attachment on this board is proving to be nearly impossible without better equipment. does anyone have tips on getting good alignment of the chip? i've reattached it a few times and always end up with at least one shorted power rail
reattaching the PCH to the dell la-k452p
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
I'm working on a Dell PowerEdge T110 server that stopped working after a stress test. I need help recovering the VPD EEPROM (AT24C02).
― HISTORY ―
I bought this server at a charity bazaar (Pequeno Cotolêngo, Brazil). I cleaned it up, installed Windows 10 LTSC, and tested it all day — heavy file transfers to 3 HDDs, driver installations, and finally added an external audio card to watch YouTube. At that point the machine shut down suddenly and never came back.
― SYMPTOMS ―
• Power supply would not arm (no PS_ON signal)...-
04-25-2026, 04:28 PM -
by TeslaI have a Dell XPS-15 (9520) with the LA-L402P motherboard. It seems to have bricked itself after a common BIOS-Firmware upgrade. Now, it just shows BIOS screen for a few seconds before turning-itself back Off (and doesn't seem to be fully Posting). I've done these many times before with no problems.
I was hoping to please have my own-thread to work-through this (hopefully successful) repair as a whole. Apart from the possible need to have a BIOS-dump fixed-up, I have a feeling I'm going to have other questions. This includes using my new XGecu-T76 for the first time (should be here... -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by MtapeKCan you help me i have my dell 14 plus that was restarted when it was updating bios firmware
it is a DB04250 not a PB14250 i didn't know if i should start a thread or post here...
Device details:- Model: Dell 14 Plus 2-in-1 DB04250
- MFG Yr: 2025
- ST:58ZXYB4
- EX:11428011760
- REG MODEL : P198G
- REG TYPE NO: P198G001
Channel: BIOS Requests ONLY!
- Loading...
