dell 3521 la-9104p no backlight
  • doctormasry
    • Dec 2019
    • 101
    • giza
    hellolaptop dell 3521 la-9104p no light on screen
    i can see data ok but no backlight
    on jlvds
    NV_PWR_SRC 18 v is ok
    3vs is ok 3.3
    lcdvdd is ok 3.3
    i replacd led screen
    and change flata ( caple between board and led )
    any idea
  • khaahk
    • Dec 2013
    • 800
    • Estonia
    Voltages on:
    pin36 INV_PWM
    pin37 DISPOFF#
    • doctormasry
      • Dec 2019
      • 101
      • giza
      Originally posted by khaahk
      Voltages on:
      pin36 INV_PWM
      pin37 DISPOFF#
      thanks
      pin36 2.5v
      pin37 0 volt
      • mon2
        • Dec 2019
        • 14480
        pin37 DISPOFF# = the '#' denotes an ACTIVE LOW signal. So with 0v here, the logic board is requesting to turn the DISPLAY OFF.
        • doctormasry
          • Dec 2019
          • 101
          • giza
          i connect pin 37 with 3 volt
          but the same problem data without backlight
          and there is data on screen
          • mon2
            • Dec 2019
            • 14480
            Locate the jumper @ RV29.
            Cut with a sharp knife to isolate the INV_PWM trace. After this cut, INV_PWM should be with only the pull-down resistor @ RV230.
            Measure the voltage on INV_PWM which should be 0v since it is not being driven.
            After this confirmation, take a piece of wire and attach to INV_PWM and 3v3. This should drive the PWM to full ON state for the backlight. If this does not work, then your backlight inside of the display assembly is defective. That is, there will be another circuit inside of the display assembly that accepts the PWM (pulse width modulation) signal to drive the multiple leds behind the LCD panel itself.
            • HTR-Informatique
              by HTR-Informatique
              02-09-2025, 06:51 AM
            • DanPoka
              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
              by DanPoka
              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
              02-15-2025, 05:05 AM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • nabilgo
              dell 3521 la9104p
              by nabilgo
              hey all
              i have dell 3521 la9104p he work only on battery and when i remove the battery and try o turn it on with charger he work for 2 seconde...
              06-10-2021, 05:51 AM
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
