ASUS GL553VD power loop problem
  • retrorepair2
    • Feb 2023
    • 92
    • United Kingdom
    I have the above here (i5, gtx1050) that had liquid damage, replaced 3 mosfets, cleared all shorts now tries to power up and power, caps lock and charging lights flash for half a second then hdd light just blips every half second forever.
    BQ IC looks fine and definitely no more shorts, power rails are pulsing along with reset, can’t work out what the issue is, does anyone have experience with a similar fault?
    someone else posted they had this issue and tried reflashing bios but didn’t solve it.
  • retrorepair2
    • Feb 2023
    • 92
    • United Kingdom
    Here’s what it’s doing. Keyboard LEDs flash too. Would an EC or BIOS reflash help?
    also suspect keyboard is shorted since when connected the laptop does nothing at all and the 3.3v on the power button jumper drops to 1.2v
    • mon2
      • Dec 2019
      • 14660
      Let me know if you need any of these.
      • retrorepair2
        • Feb 2023
        • 92
        • United Kingdom
        Further to this, because it keeps resetting I can’t reliably see with my DMM if +5VS is being correctly generated. That said, isn’t +5VS a standby voltage? So should be present at all times? Would this indicate the voltage isn’t being generated correctly? It’s not short
        • mon2
          • Dec 2019
          • 14660
          Remove all power. Meter in resistance mode. Measure the resistance to ground of each inductor. Hunting for a lower than normal resistance on each power rail.
          Test the resistance on the 5v vbus line which are linked to the USB ports. The USB load switch is a common point of failure.
          • retrorepair2
            • Feb 2023
            • 92
            • United Kingdom
            Great I will do, thank you
            most read megs
            The EC and BIOS would be useful:
            Asus ZX553V
            GL553VD Rev 2.0
            SN H6N0CV01P629223
            I guess 4-8 ohm on CPU rail would be normal on inductors
            • m1ch43lzm
              • Mar 2019
              • 900
              • Peru
              Bios requests go here
              https://www.badcaps.net/forum/troubl...53vd#post70226
              Post there the required info (S/N, board model, laptop model) along with a backup of your existing BIOS, someone there will supply a working BIOS for you to try
              Read the BIOS chip 2-3 times, confirm you got a good dump by comparing the 3 files with hex editor, and check that it's not empty (FF FF FF FF ...) before trying another BIOS
              • mon2
                • Dec 2019
                • 14660
                Posted the bios images from my database under post # 87
                https://www.badcaps.net/forum/troubl...-gl553vd/page5
                • retrorepair2
                  • Feb 2023
                  • 92
                  • United Kingdom
                  Thank you really appreciate that. Been going through everything and still not finding any shorts or low resistances except cpu and gpu (2-8 ohm). Think bios is next.
                  • mon2
                    • Dec 2019
                    • 14660
                    Cpu and gpu are low voltage rails so will be low resistance by design. To me, they look ok.
                    • retrorepair2
                      • Feb 2023
                      • 92
                      • United Kingdom
                      Ok great, now to figure out how to flash this bios
                      • m1ch43lzm
                        • Mar 2019
                        • 900
                        • Peru
                        You need a SPI flash programmer, the cheapest is the CH341A, also get a SOP8 200mil adapter, that requires desoldering the BIOS chip from the board, there's also a SOP8 clip but it will take some tries to get it to properly make a connection
                        Check here for more info https://www.badcaps.net/forum/troubl...21#post1622421
                        As I said before, it's best to make a backup of the existing contents on the BIOS chip before flashing another BIOS, the original BIOS also contains the serial number and Windows key, that has to be transfered to the "new" BIOS with a hex editor
                        • retrorepair2
                          • Feb 2023
                          • 92
                          • United Kingdom
                          Replaced a mosfet and accidently bridged 19v and gnd. Nice hole in the board and perminant short so that's that. Damn, this would have been perfect for me. Back to my 2013 Celeron machine I guess.
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • ShadowAi
                            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                            by ShadowAi
                            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                            03-15-2024, 10:46 AM
                          • meraklinetx
                            Asus Z97-a power cycle, no boot no cpu voltage
                            by meraklinetx
                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                            05-10-2023, 06:08 AM
