macbook air m1 820-02020 cant restore on reinstall osx.
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    hi all, just got this macbook from a parent. it was previously water spilled. my cousing took it to a repair shop where they cleaned the water spot corrosion and make it boot again, but they were not able to reinstall osx. after that my cousing bring it to me, but im facing same problem. neither in dfu, usb osx installation media , neither internet recovery works.
    in disk utility, it see 245gb ssd, i can inizialize it and start reinstalling osx, but at some point it will give me error. i read somewhere that it could be a bad caps, but all values loks good. i checked also pp5v_s2 coil and it's not shorted.
    im asking here if u can guide me to fine the problem.
    PS: the cpu heatsink is really cold. could that be because board was ultrasonic clean and it clean also the thermal paste from cpu die to cpu shield ? when i google for air m1 cpu temp i see lots of people blame for itbeing really hot, while the whole time i had the pc turned on , it was really cold on cpu side.
  • mon2
    • 14342
    What is the error?
    What are the voltage to ground measurements for the ssd rails?
    • dellxps15
      • Feb 2014
      • 1591
      • italy
      hi mon
      diode value are the following:
      2,25 : 0.900
      1,25: 0.640
      0.88 : 1.220
      0,9 and 1,2 i have to remove board as they are on the other side of it.
      the error is: there was a problem during installation. it's just a generic error....
      • dellxps15
        • Feb 2014
        • 1591
        • italy
        fixed it yesterday after getting in more error message focus.
        https://www.youtube.com/watch?v=duXxWDUk2UI
        i come into this video and after doing that macbook worked again
        • dbuergi
          Water damaged MacBook Air A1932 AmrestoreErrorDomin Error-9 trying to restore with configurator
          by dbuergi
          this Macbook was stuck at 5v and didn't start because of some water damage. I was able to clean everything and the board started. So i put everything back together and the Macbook seems to boot with 20v, 1,4A and 29W. So i decided a DFU recovery. At 50% of the system repair i get the error massage from the title. Display stays black and no Apple logo. Both repair and recovery don't work.
          Is there anything i can do?
          11-19-2024, 09:27 AM
        • dbuergi
          Restore solder pads for SMC on MacBook A1466
          by dbuergi
          i got a A1466 logic board for spare parts but it looks like the SMC ist bad. I got several spares but somehow i was too fast while removing it and ripped some pads off. You can see the damage attached.
          Just for experience i would like to restore the lost pads but before i start (haven't done this before) do you have some hints or tutorials how to do it?
          As written i want to improve skills so it doesnt matter if it takes longer.
          12-29-2024, 10:24 AM
        • Stephen
          A2338 MacBook Pro M1 Issue with DFU Restore or revive.
          by Stephen
          Customer came in with a board issue, board looks clean, board turns on, he did a software update and he got the infamous Apple boot loop logo. He took it to Apple and Apple said he needed a new board. They attempted to DFU revive restore etc no luck. The board is stuck on the (!) point. I tried DFU myself and no luck. Nothing, board boots up goes into DFU computer turns on with Apple logo when applying the patch and nothing it gets stuck at halfway point and hangs on. I was wondering if anyone has had any experience with this particular issue. Board isn't liquid damage from what I can tell...
          10-11-2024, 11:14 AM
        • survivalbloke
          Macbook A1932 - ran restore in DFU, but lock icon halfway through?
          by survivalbloke
          I've got a macbook air A1932 here which a customer abandoned. I'd like to get it running so I can sell but having difficulty. I ran it in DFU mode through apple configurator, and chose 'Restore' and it went through to step 4, then it looked like it was making progress when all of a sudden the large, grey EFI lock showed on Apple configurator. Isn't DFU supposed to reflash the firmware?
          I have a DS-809SE but there is no SAM port on this board. Also, I removed the board and examined but didn't notice any BIOS-looking chip.
          Where to go from here?
          07-14-2023, 03:03 PM
        • SarcasticOP
          General question about MacBook power rails for repair.
          by SarcasticOP
          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
          • PPBUS_G3H (12.6V-12.8V)
            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
          • PP3V42_G3H (3.42V)
            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
          • PPVRTC_G3H (3.3V)
            • This
          12-12-2024, 05:50 PM
