msi ms-15ck1 ene ic programming pins
  • grigore3110am
    • May 2024
    • 5
    i replaced ene KB9028G i need the pinout on the kb connector to program it i was unable to find anywhere the pinout
  • khaahk
    • Dec 2013
    • 812
    • Estonia
    Vertyanov lists it as this:
    KB_pins=40 RIGHT DOWN 05MM KSO3=4 KSI4=13 KSI7=16 KSI6=15 KSI5=14
    • grigore3110am
      • May 2024
      • 5
      i extracted 128kb ecu fw from bios i programmed it nothing happens
      • grigore3110am
        • May 2024
        • 5
        does any one have a picture with KB9028G area , i replaced KB9028G because it had a hole in it and it was shorting pu09 on the other side of the motherboard.
        • khaahk
          • Dec 2013
          • 812
          • Estonia
          https://t.me/BoardsScanRepo/266/2894
          • langbaobao
            DIY 3D-Printer WSON8 Pogo Pin Adapter
            by langbaobao
            Hi.
            I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
            I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
            01-08-2024, 05:58 PM
          • corrize
            Where to find a very small fpc connector 0.3mm between 2 pins ?
            by corrize
            Hello, I search this connector (oxydated).
            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
            Do you know how to find this connector please ? What is the exact name for find it ?
            08-06-2024, 05:25 PM
          • H34TO
            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
            by H34TO
            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
            06-17-2025, 07:17 AM
          • pickledegg
            Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
            by pickledegg
            Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
            I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
            10-02-2024, 04:54 PM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
