yoga9 3v3 5v fluctuating
  • koby058
    • Jan 2017
    • 382
    • israel
    Hi
    board model: NM-D992
    type c remains on 5v. when i connect it the 3.3VALW and 5VALW fluctuating. can someone please help understand why?
    main power rail voltage 13v
    till now i have tried:
    measured all coils resistance looks ok
    replaced RT6585CGQW to a brand new one
    replaced all mosfets for 3.3v regulator and the dual mosfet for 5v regulator
    happen both on DC power and on battery
    issue remains
    video
    schematic attached
  • mon2
    • Dec 2019
    • 14238
    Remove all power. Meter in resistance mode. Measure the resistance to ground of the rails that are fluctuating.
    What are the measurements for each?
    • koby058
      • Jan 2017
      • 382
      • israel
      Hi and thanks for trying to help
      on the 3.3v coil 5.87K
      on the 5v coil 5.78K
      • mon2
        • Dec 2019
        • 14238
        These are not shorted rails. What are the actual voltage values on each of these rails? How badly are they fluctuating? Share the range(s).
        • koby058
          • Jan 2017
          • 382
          • israel
          i have shared a video. in the first post. is that good enough?
          • mon2
            • Dec 2019
            • 14238
            I totally missed that. You are power cycling.
            Test if the EN (enable) pins are also pulsing in the same manner or not.
            • koby058
              • Jan 2017
              • 382
              • israel
              Yes, indeed the enable pins are also pulsing in the same manner
              • mon2
                • Dec 2019
                • 14238
                Measure the voltage to ground of:
                3VALW_TBTB
                VCC3_LDO_PD1
                VBUS_TBTA
                VBUS_TBTB
                +3VSUS
                • koby058
                  • Jan 2017
                  • 382
                  • israel
                  3VALW_TBTB 0v
                  VCC3_LDO_PD1 3.46v
                  VBUS_TBTA 0.15v
                  VBUS_TBTB 5.2v
                  +3VSUS jumping between 0 to 0.5v
                  could an corapted EC firmware cause this?
                  • mon2
                    • Dec 2019
                    • 14238
                    Remove all power. Measure the resistance to ground of +3VSUS.
                    3VALW_TBTB 0v
                    Measure the resistance to ground of 3VALW_TBTB.
                    What is the resistance in ohms?
                    • koby058
                      • Jan 2017
                      • 382
                      • israel
                      due to a vacation i will update here only in the week after next week
                      • cind12
                        GTX 1080 TI Gigabyte Aorus low resistance on vmem
                        by cind12
                        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                        Resistance on 12V 4K ohms (Power present when on)
                        Resistance on 12V PEX 4K ohms...
                        12-08-2023, 09:09 AM
                      • Nagy Daniel
                        Lowest possible resistance on laptop motherboard rail - Guide Table request
                        by Nagy Daniel
                        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                        So, I generated a table with AI so I can...
                        03-04-2025, 08:24 AM
                      • triplefour
                        ONN 100012588 Has fluctuating Voltage on PSU 12v
                        by triplefour
                        Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                        anyway i go to this guys house to look at an ONN 100012588
                        this is my first time looking at one of these brand of TV's.
                        TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                        09-14-2022, 07:41 PM
                      • Cemal Odabasioglu
                        MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                        by Cemal Odabasioglu
                        I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                        Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                        Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                        Observations...
                        01-14-2025, 03:54 PM
                      • disorder
                        HP 2311 display, 3.3v regulator fried, need help to replace
                        by disorder
                        hello,
                        i have a hp display 2311 to repair, totaly dead
                        on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                        i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                        thank you
                        07-27-2025, 04:34 AM
