Lenovo E15 Gen.3 NM-D481 No starting and charging via USB-C, The device starts only via the battery.
  • master3112
    • Mar 2024
    • 85
    • Slovakia
    I have a Lenovo E15 Gen.3, motherboard NM-D481 with a defective USB-C port. The device starts with battery. When connected to the USB-C power supply, it does not start or charge. 20V is present at the input of the UT5 (High voltage USB PD power switch), 0V at the output
    UT5 pin 3 (SNK_PS_EN) =0V
    RPT3 Pin1+2 LDO 3V3 present
    I suspect that the UT2 USB-C power controller is defective because the UT5 is only controlled by the UT2. However, the UT2 supplies on pin 33 (+LDO_3V3) which makes me wonder if it is defective after all. Unfortunately I don't have it here to test it.
    Has anyone had behavior like this?
    THX
  • mon2
    • Dec 2019
    • 14573
    Link a schematic.
    My schematic for the NM-D481 contains a WLCSP packaged device @ UT5 so there is no pin 3.
    • master3112
      • Mar 2024
      • 85
      • Slovakia
      Its Pin A3
      Click image for larger version  Name:	image.png Views:	0 Size:	6.9 KB ID:	3696177Click image for larger version  Name:	image.png Views:	0 Size:	33.2 KB ID:	3696178
      • mon2
        • Dec 2019
        • 14573
        Ok - we have the same schematic but the BV is referencing the pins in a strange order. They should be using the schematic pin names.
        So pin #3 = A3 on the WLCSP package and is an active LOW signal (denoted by the # suffix). When this pin is LOW = 0v, the signal is active and is being requested to pass the voltage through the load switch.
        You have 0v = OK to enable and pass the voltage through.
        To confirm, you have voltage going IN to this load switch but not OUT of the load switch?
        Remove all power. Measure the resistance to ground at the output of this load switch. This can be done at any of the VINTx pins. What is the resistance?
        If the resistance is too low, the switch will not be able to handle the excessive load and turn off or is now defective.
        See attached.
        • master3112
          • Mar 2024
          • 85
          • Slovakia
          I have 3M ohm at the output of the UT5.
          I have 20V at the input of the UT5.
          So the UT5 is defective and don´t switch?
          Can I manually feed 20V into the output of the UT5 to test whether the device starts? Normally I can't damage anything, can I?
          • mon2
            • Dec 2019
            • 14573
            Agree, output is not shorted so I would think it is safe to bypass it. To be safer, do not connect the battery for this test. Only the power adapter to the board power path is of interest.
            To me, this load switch is defective and needs to be replaced for a fix.
            • master3112
              • Mar 2024
              • 85
              • Slovakia
              mon2 thanks for you input.
              I did not know that this component is open when 0V voltage is applied. Your tip has helped me a lot and I have learned something again.
              I will order the NX20P5090UK and replace them. I will give feedback as soon as I have completed the repair
              THX
              • mon2
                • Dec 2019
                • 14573
                Good. Suspecting that the internal mosfets are defective.
                Here is a truth table for this part and the highlighted case that is for the normal operation on your board.
                • master3112
                  • Mar 2024
                  • 85
                  • Slovakia
                  Hello mon2,
                  I have now received and installed the NX20P5090. The device is working again.
                  Thank you for your support.
                  • mon2
                    • Dec 2019
                    • 14573
                    Very good to hear. Thanks for the positive update.
                      LENOVO ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 ThinkCentre M i5-8500T Specification for Upgrade or Repair
                      This specification for the LENOVO ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 boardview and ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                      09-12-2024, 01:58 PM
                    • chaos-theory
                      Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                      by chaos-theory
                      I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                      Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                      03-14-2025, 05:37 PM
                    • rilley
                      MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                      by rilley
                      I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                      I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                      My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                      And the resistor L4004 is literally burned.
                      From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                      07-10-2024, 01:57 AM
                    • drscoot
                      usbc connector replacement on mobile
                      by drscoot
                      I replaced the broken usbc connector on this Ciontek CS50 mobile device. It worked fine afterwards, although it looks like the battery went down quickly and the device got warm at the back (battery section). After putting it in standby for a while it didn't came back anymore?
                      The battery is still charging (red led), but no power on.
                      I had another look at the usbc connector, it looks like one of the components is melted down (blue marking)? I have a picture of an untouched device and then the repaired device with 2 pictures; what are these components with B1 and PB marking? Are these...
                      07-13-2025, 02:37 PM
                    • Syseng
                      Lenovo P14s Gen 5 SVP unlock
                      by Syseng
                      This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                      The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                      06-22-2025, 07:44 AM
