ASUS X571 no power : battery issue?
  • mon2
    • Dec 2019
    • 14369
    Review if there is a coin cell battery on the board. If yes, test the voltage to ground of that battery. This battery may need to be replaced with a fresh one. Often, the ec is powered by the coin cell battery when the main power rail is off.
    • mkdj
      • Mar 2025
      • 31
      • France
      Dear mon2,
      Thank you for your help. There is no coin cell battery on this board.
      Regards,
      mkdj
      • mon2
        • Dec 2019
        • 14369
        Remove all power. Meter in resistance mode. Measure the resistance to ground of this J5 trace for the EC power rail that is absent. We are testing to see if the rail is being shorted so the voltage is missing.
        • mkdj
          • Mar 2025
          • 31
          • France
          Dear mon2,
          Value of resistance to ground is 7.5 kOhm. So there is no short to ground on the +3V power rail.
          Regards,
          mkdj
          • mkdj
            • Mar 2025
            • 31
            • France
            Dear all,
            I am still trying to figure out what the problem on this specific board is. There is no short on the +3V power rail. But it is at 0V. Also, I don't know how the +3V signal is created, so I can't diagnose anything. Schematics are not available, and I am stuck with the boardview, which does not help me to figure out how the +3V power rail is created.
            I am keen on having any information on what to do now. It is a nice machine, and I would like at least to understand how the +3V signal is supposed to be created on this particular board.
            Regards,
            mkdj
            • mon2
              • Dec 2019
              • 14369
              Review the actual regulator and its pinout for the +3V power rail. There should be an EN (enable) pin on this component. This EN signal will be created by either a resistor based voltage divider OR driven by the EC controller. The EC controller is often backed by a coin cell battery or similar. Just this week alone, had 3 cases of where the coin cell battery caused the logic board to appear to be dead. Replacing the battery fixed each of the 3 cases. Do investigate this if you see a coin cell battery.
              • mkdj
                • Mar 2025
                • 31
                • France
                #27
                Dear mon2,
                I can't find the actual regulator for the +3V rail on this board, which is why I am stuck. Also, there is no coin cell battery on this motherboard.
                However, I have news. As the board when plugged in is taking 20mA, I tried to use my thermal camera to see if there was a chip heating. And I have found that something small is heating next to a PWM controller. Reference of the chip is MP2884AGU, and datasheet is here: https://www.alldatasheet.com/datashe...MP2884AGU.html
                I don't know exactly what is heating (the chip itself or something next to it) because my thermal camera has really low resolution and parallax issues. I tried to use alcohol and a freeze spray to locate precisely the heating element, but without success. I guess it is not heating enough to be detected.
                Could this chip be the one creating the +3V signal? And because it is heating, it would mean that it does not work properly, and can't create the signal?
                Or is the fact that the chip is heating a normal behavior?
                Regards,
                mkdj
                • mon2
                  • Dec 2019
                  • 14369
                  No, this regulator is not the one responsible for the +3V always on rail. The datasheet shows this regulator as a multi-phase regulator meaning it is intended for much heavier loads such as the CPU or GPU. Much like humans, more manual labour can be performed if multiple people are involved instead of a single person, this regulator takes turns turning on one power leg of this multiphase output then turns this one off and turns on the next and so on. Each take a quick on/off action to not burden the single leg. It may be normal to see a temp rise on this regulator since the current draws are heavy.
                  The board is only consuming 20mA so very little current draw. As a comparison, a LED will be 5-10mA for a signal led.
                  Locate a known component that makes use of the 3v3 rail. Place one meter probe there. Meter in diode mode. Touch your meter probes to confirm there is a tone beep. Be sure there is no power to the board. Now probe each inductor on the board till you hear a tone beep. The +3v3 regulator should be near by. Try this approach.
                  • mkdj
                    • Mar 2025
                    • 31
                    • France
                    #29
                    Dear mon2,
                    Thank you for the explanation of the role of the multi-phase regulator. I believe I have found the 3V regulator. I have used the boardview and checked all the inductors. There is one that has a +3V_S5 signal, and that is connected to PU22. This chip is SY8286BRAC, and according to the datasheet, it is a stepdown DC/DC regulator : https://www.alldatasheet.com/datashe...GY/SY8286.html
                    I have checked the pins of this regulator. And I have noticed VIN is absent...
                    Back to square one : without battery, I have checked the voltage on the first mosfet, and I have 19V on drain, but nothing on the source. Gate voltage is no more than 60mV. So I have checked the charging IC as you suggested before.
                    REGN voltage @ pin #24 is 6V : ok
                    Voltage at the ACDRV pin (pin #4) is no more than 70mV : not ok
                    I wanted to plug the battery and see if the values on the charging IC were different. Turned out to be a bad idea: fire and smoke went out of the 3.3V regulator. I immediately disconnected the battery, but this regulator is now dead...
                    I think the reason why this happened is because, when measuring the voltage at the 3.3V regulator, I probably created a short somewhere because of my multi-meter probes. Because I think I saw 19V on the VIN pins of the regulator for a few seconds, then it disappeared. I could not read 19V anymore at this location. Then I noticed that I did not have 19V on the first mosftet anymore.
                    Now that this board is probably dead, I will try to learn from it. I will try to find shorts, remove them, maybe replace the charging IC, and see what happens. I may come back to keep you updated, as this thread may help other people.
                    Regards,
                    mkdj
                    • mon2
                      • Dec 2019
                      • 14369
                      Goto AliExpress. Order a few spares of all linked parts. Order replacements for this 3v3 regulator, each of the mosfets in the power path from the power adapter to the main board, mosfets for the charger ic and and also the charger ic. Be sure the ics have the same suffix as the original part number. The total bill will be under $10usd with spares. Then replace this dead 3v3 regulator first. Do purchase fine tipped meter probes as well.
                      • mkdj
                        • Mar 2025
                        • 31
                        • France
                        #31
                        Dear mon2,
                        Thank you for your comments. Before ordering anything, I tried something.
                        I have noticed that I had now 2 shorts on two different inductors: the 3.3V(which seems obvious as the regulator burned), but also on a 1.05V rail, which goes to the chipset nearby. Values of resistance were close to 0 Ohm at both inductors, and I did not have these shorts before.
                        Then I tried to remove the burned regulator. Doing so, as it and the board beneath it was burned, I ripped off some pads. I cleaned it. I checked again for short at the inductor of the 3.3V rail, and I still had a short to ground.
                        So I injected 0.7V at this coil, used my thermal camera, and noticed that the chipset was heating.
                        My question is: based on these pieces of information, is it still worth buying chips for this board? Or is it definitely dead?
                        Regards,
                        mkdj
                        • mon2
                          • Dec 2019
                          • 14369
                          Which chipset is heating up during the injection? Is it the CPU / PCH (should be the very large chip under the heatsink)? If yes, then this is a no fix. The PCH is also a consumer of the 3v3 rail for its IO pins.
                          • mkdj
                            • Mar 2025
                            • 31
                            • France
                            #33
                            Dear mon2,
                            It is not the CPU / PCH under the heatsink. It is the U7 chip on the boardview. Reference of the chip is : C.S FH82HM370 B0 FCBGA874
                            It is the chip circled in red:
                            Regards,
                            mkdj
                            • mon2
                              • Dec 2019
                              • 14369
                              This is the PCH. To us, it would be a no fix. Too many balls onboard unless you feel comfortable to replace this device. The PCH is the host USB controller, etc. to assorted peripherals. Perhaps a transient through the USB port that killed this device.
                              If you wish to pursue the replacement, here is the procedure:
                              https://www.youtube.com/watch?v=eVDp...channel=Laptex
                              You can also check shops local to you for this service to see if the repair is practical to pursue. Check Aliexpress for (affordable??) replacement PCH controllers but only from reputable vendors. On a side note, we are designing a new widget for PCI Express. Our older products are becoming stale on sourcing the EOL devices. Working with the silicon company directly (ironically it is Asus Semiconductor division) - we designed in their controllers because they are active. Now about to prototype a small batch on our machinery and the cost of the parts is 5x what we originally discussed. Crazy. We found them on Aliexpress and the vendor (SUMS) stated they are 100% new and original. Purchased 20-30 parts for testing. The parts arrived in the past 48 hours and the reflections off the TQFP pins clearly show that the parts are removed and retinned. Each part on this cut tape & reel has a different date code. This will be a frankenstein build. In the live production we will only work with the same datecodes of parts but it is important to work with a stable supplier if you wish to replace this part. Personally have not replaced a PCH in the past.
                              • dhenion
                                Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                                by dhenion
                                I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                                The original board was:
                                ASUS X510UNR REV 3.0 A
                                The replacement board is:
                                ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                                It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                                01-30-2024, 01:45 PM
                              • rob777
                                Asus TUF won’t run off battery
                                by rob777
                                I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                                I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                                Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                                Thanks....
                                05-27-2025, 07:07 PM
                              • Iherduleikgemz
                                Asus FX505DY - Battery not charging - BQ24780S
                                by Iherduleikgemz
                                Hello everyone
                                I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                                I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                                01-13-2025, 03:54 PM
                              • cope
                                Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                                by cope
                                I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                                Some history:
                                Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                                As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                                Now, with a new battery the system will start up and run off...
                                05-13-2024, 09:40 AM
                              • dr.thodt
                                Asus GA401Q only working from battery
                                by dr.thodt
                                I have an Asus GA401Q which only works from battery power. That suggests the board is mainly fine.
                                The battery status is 255%, also with a brand new battery.
                                The BQ24800 was replaced since it showed signs that it was part of the problem, but possibly the battery was flat at that moment.
                                If I insert the 19V adapter in the DC jack and measure the current sense resistor's voltage it fluctuates between 0V and 19.5V and the keyboard backlight flashes (probably because the battery is almost flat. It does the same when I run the laptop from battery).
                                There's a...
                                12-20-2024, 08:23 AM
