ASUS X571 no power : battery issue?
  • mkdj
    • Mar 2025
    • 15
    • France
    Mark and model: ASUS X571
    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
    Tests already made:
    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
    - I have removed the battery : laptop won't power on. What surprises me is that the LED battery indicator is blinking amber, which means, according to the manual, that laptop works on battery power, and that battery is less than 10%. But battery is not present. I was expecting to see a solid amber or white LED indicator, indicating that laptop is connected to AC.
    A first question: are some laptops unable to boot if internal battery is not present, and how can I know if this specific one needs a plugged-in battery to boot?
    - I have extracted the motherboard and made voltage measurements on the battery MOSFET (PQ16).
    - Without battery, measure on Gate (PIN #4) is not stable, fluctuates between 6.9 and 8.4V. Signal VBAT anywhere on the board has the same fluctuations, although there is no battery connected.
    - With battery, measure on Gate is stable at 12.5V.
    Second question: is it a normal behavior that, without battery, I measure a VBAT signal that is fluctuating between 6.9 and 8.4V?
    This is one of my first board level repairs, I may be completely off track on finding the fault. Maybe I am looking at the wrong item. Feel free to tell me so, or to ask me any questions you would have. Attached is boardview of the board, if needed.
    Regards,
    mkdj
  • mkdj
    • Mar 2025
    • 15
    • France
    Dear all,
    I am still investigating on this board.
    As said before, when no battery is present, the charging chip PU13 (BQ24780) gives unstable 24780-BATDRV signal, fluctuating between 6.9 and 8.4V. However, signal VIN is 19V after the shunt resistor.
    If we have power on the main power rail, does that mean that the charging chip BQ24780 is good? Or can we have 19V on the main power rail AND a faulty charging chip which prevents the laptop from turning on?
    Many thanks for your help,
    mkdj
    • mon2
      • Dec 2019
      • 14150
      Share the voltage to ground on each pin on the battery connector. The SCL / SDA pins are most of concern since they are linked to the SMBUS interface. Perhaps an ESD event took out the TVS diodes and are preventing the proper communication over the SMBUS interface.
      • mkdj
        • Mar 2025
        • 15
        • France
        Thank you mon2 for you help. Below are the readings of voltage to ground of each pins of the battery connector.
        Click image for larger version  Name:	dataurl301641.png Views:	0 Size:	18.0 KB ID:	3684335
        • 1 : fluctuating between 6.86 and 8.40V
        • 2 : same behavior as pin #1
        • 3 : almost stable (fluctuates within a 3.29-3.30V range)
        • 4 : almost stable (fluctuates within a 3.28-3.30V range)
        • 6 : 0V
        • 7 : 0V
        • 8 : 0V
        • mon2
          • Dec 2019
          • 14150
          Ok. Missed the charger in 2nd post.
          Locate the dcin mosfets. Share their topside markings.
          Are these n-channel type? Should be.
          Remove all power. Meter in resistance mode.
          Measure the resistance across each mosfet:
          source - drain
          source - gate
          gate - drain
          Post each measurement in ohms.
          often, the fault is in the first 2 dcin mosfets for your case. If available, replace the first mosfet and then the 2nd for testing. The acdrv must be 25v if all is well. Test it first.
          • mkdj
            • Mar 2025
            • 15
            • France
            Dear mon2,
            Not sure if I understand the first question correctly, but charger IC is BQ24780.
            DCIN MOSFET #1 (PQ20)
            N-MOSFET AONS32306 (from boardview)
            32306 GL9A1F (from topside marking)
            N-Channel (according to datasheet)
            source - drain : 1.94 MOhm
            source - gate : 2.57 MOhm
            gate - drain : 3.74 MOhm
            DCIN MOSFET #2 (PQ21)
            MOSFET AON6414AL (from boardview)
            6414A GL0S15 (from topside marking)
            source - drain : 2.76 MOhm
            source - gate : 2.56 MOhm
            gate - drain : 3.65 MOhm
            For the record, I have also measured the battery MOSFET (PQ16)
            source - drain : 227 kOhm (but starts far away from this value and converge towards it)
            source - gate : 1.7 MOhm
            gate - drain : 1.95 MOhm
            These MOSFETS look good to me, don't they?
            • mon2
              • Dec 2019
              • 14150
              Only the battery mosfet is a suspect with the source / drain measurement. As a quick test, it can be fluxed and removed to isolate this part off the board. The battery should still charge without this part onboard.
              What is the gate voltage of each of the DCin mosfets with the adapter attached to the logic board? Being N-channel, the enable voltage should be adapter_voltage + REGN voltage = ~25volts.
              Confirm this voltage if absent on the gate pins at the ACDRV pin on the charger IC = pin #4. Also confirm, if necessary, the REGN voltage @ pin #24.
              • mkdj
                • Mar 2025
                • 15
                • France
                Dear mon2,
                With adapter plugged in:
                - Voltage is indeed 25.76V stable at the gates of the two DCIN MOSFETS.
                - Voltage at the ACDRV pin on the charger IC (pin #4) fluctuates between 6.86 and 8.40V.
                - REGN voltage (pin #24 of charging IC) is 0V.
                I don't know if it is relevant, but I have checked voltages of the battery MOSFET with the adapter plugged in, and no battery present:
                - Source voltage: fluctuates between 6.89V and 8.40V
                - Drain voltage: stable 19.8V
                - Gate voltage: fluctuates between 6.83V and 8.40V
                Regards,
                mkdj
                • mon2
                  • Dec 2019
                  • 14150
                  If you have ~25v on the gates of the DCin mosfets, then the ACDRV pin is also @ same voltage since this is the boosted voltage output pin on this charger IC. Perhaps measuring the wrong pins on the charger IC?
                  Also, the same for REGN. If you have ~25v on the gate pins then REGN is also working and should be ~6 volts here.
                  What are the topside markings of the battery mosfet? It should be an N-channel type so for this to enable, the gate pin must be also higher than the voltage being passed between source / drain pins of this mosfet. For the above case, with only the adapter connected, this mosfet should be OFF since the gate voltage is lower, then the N-channel mosfet will be disabled. Looks to be ok here. If in doubt, you can flux and remove this mosfet.
                  The battery should receive a valid charge voltage if the power adapter is powering this logic board.
                  At this time, is there any charge on the battery? If you connect the power adapter & battery, what are the voltages on the battery connector? Also share the voltage markings on the battery itself. To charge this battery, the charger voltage should be slightly higher.
                  • mkdj
                    • Mar 2025
                    • 15
                    • France
                    Dear mon2,
                    My mistake, I indeed measured the wrong pins on charger IC. Find below correct values:
                    - Voltage at the ACDRV pin on the charger IC (pin #4) is 25.77V.
                    - REGN voltage (pin #24 of charging IC) is 6.02V.
                    Characteristics of the battery mosfet:
                    N-Channel (according to datasheet)​
                    There is charge on the battery (this is the first thing I tested, before extracting the motherboard, see first post). I have checked one more time, and my ampmeter says the board is drawing approx 0.550A with battery plugged in. Voltages on the battery connector are then 12.49V for pins #1 and #2. Pins #3 and #4 are 3.25V. Battery markings are +11.52V / 42Wh.
                    Regards,
                    mkdj
                    • mon2
                      • Dec 2019
                      • 14150
                      Unless the battery is dry, it should be charging. If you leave it plugged in for a few hours, will the current draw increase? Suggest to measure the voltage to ground on each and every inductor on the board. Perhaps some other issue that is causing a local buck regulator to turn OFF. You can also wait a while with hopes that the battery will fully charge and then perhaps participate in the booting of this logic board. Personally do not have experience with such units other than macbooks which do require a fully charged battery to boot the box. The 0.5A current draw is still low for a laptop so wondering if there is a shorted part onboard. You can hunt for it by removing all power -> measure the resistance to ground of each inductor.
                      • mkdj
                        • Mar 2025
                        • 15
                        • France
                        Thank you very much mon2 for the time you spent with me on this board. I will continue investigating next Monday. I will keep on feeding this post with my updates, so that it can help others.
                        Regards,
                        mkdj
                        • mkdj
                          • Mar 2025
                          • 15
                          • France
                          Dear all,
                          Without battery but with the charger, I have checked voltage to ground of every inductor on the board. I have 0V everywhere, except at the PL19, which is the inductor closest to the battery connector. Here I got a voltage fluctuating around 8V. According to the boardview, this is VBAT voltage.
                          Without power, I have also measured all resistance to ground of each inductor. I have fairly low values on some of them. I have indicated the voltage they should deliver (signals taken from Boardview):
                          42 Ohm @PL8 : +0.95V_VCCIO (looks like it goes mainly to the CPU)
                          170 Ohm @PL5 : 1.2V_SUS (looks like it goes mainly to the RAM)
                          66 Ohm @PL13 : +1.05V_S5
                          I have no resistance <5 Ohm that would have clearly indicated me the presence of a short-circuit.
                          Also, I would like to insist that I do have VIN (19V) on the board. But no other voltage levels at the inductors (except VBAT fluctuating around 8V as stated above).
                          Any thoughts of what could I do now?
                          Regards,
                          mkdj
                          • mon2
                            • Dec 2019
                            • 14150
                            Low voltage rails will be low in resistance by design. These measurements look ok to me. Not shorted.
                            What is the voltage to ground on pin#1 on the charger IC? pin #2 on the charger IC? Connect the adapter only to measure.
                            Then connect both, the adapter and battery. Test these 2 pins again for their voltages.
                            • mkdj
                              • Mar 2025
                              • 15
                              • France
                              Dear mon2,
                              Thanks for being here again. Please find below the voltages to ground on pin#1 (ACN) and pin#2 (ACP) of the charger IC (BQ24780). Note that I am using a lab power supply which I have set to 19.7V output.
                              With the power supply only:
                              pin #1 : 19.68V steady
                              pin #2 : 19.68V steady
                              With the power supply AND the battery:
                              pin #1 : 19.49V steady
                              pin #2 : 19.49V steady
                              Regards,
                              mkdj
                              • mon2
                                • Dec 2019
                                • 14150
                                These are good readings. This implies the main power rail is ok. Measure the voltage to ground of the ALW rails which must be always on to power devices like the EC controller - used by the keyboard, etc. to boot the board. Confirm that the EC is being powered. The EC will have KBx pins onboard and are used to decode and debounce the keyboard keys. It is often a larger QFP or BGA device due to the use of the many IO pins.
                                • mkdj
                                  • Mar 2025
                                  • 15
                                  • France
                                  Dear mon2,
                                  By searching the signals in the Boardview file I can't find any signals called ALW or ALWON.
                                  However, I have found the EC chip, which is the IT8987. I have found another schematic of this EC to find out which PIN should receive power :
                                  If I am right, VCC should be on pin J5 of the EC.
                                  Looking now at the boardview of my ASUS, pin J5 should be fed by a signal called +3V. However, when I measure the +3V signal anywhere on the board, it gives me 0V. To me, that means that the +3V power rail is not created, and the EC can't be powered, hence the motherboard not booting.
                                  I then try to find where the +3V should be created, to continue my investigation, but I am stuck there. Usually there is a 3V/5V chip (or one 3V and one 5V chip), but there is nothing like that on this board. There was someone on this forum that asked the same question a few years ago, but the thread stopped without having a relevant answer.
                                  Regards,
                                  mkdj
                                  • mon2
                                    • Dec 2019
                                    • 14150
                                    Correct on your comments. Often, the techs end up fixing the fault and go into hiding in the witness protection program. Scummy. Where possible, each thread should offer closure for the next reader.
                                    Meter in DIODE mode. Touch your meter probes and the meter should tone beep. Place one meter probe onto the missing +3V rail on the IT8987. Other probe on any inductor on the board. Keep hunting for an inductor till you hear the tone beep. The ALW (always) rail regulator should be nearby. Let us try this approach first although it is possible that this rail is fed by a LDO in which case, the inductor will not tone beep. Just start with this approach as it will only take a minute or 2 of hunting. Post your updates.
                                    • mkdj
                                      • Mar 2025
                                      • 15
                                      • France
                                      Dear mon2,
                                      I have checked the main 6 inductors, and it did not beep. Values measured goes from 0.4 to 1.8. Please note that as the IT897 and the inductors are located in opposite sides of the board, I had to place my probe on another component on the same side of the board as the inductors (I used the boardview to find another component on the +3V signal on the other side of the board).
                                      Besides, the boardview does not indicate that an inductor (PLxx) is located on the net of the +3V signal:
                                      Regards,
                                      mkdj
                                      • dhenion
                                        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                                        by dhenion
                                        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                                        The original board was:
                                        ASUS X510UNR REV 3.0 A
                                        The replacement board is:
                                        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                                        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                                        01-30-2024, 01:45 PM
                                      • rob777
                                        Asus TUF won’t run off battery
                                        by rob777
                                        I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                                        I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                                        Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                                        Thanks....
                                        05-27-2025, 07:07 PM
                                      • Iherduleikgemz
                                        Asus FX505DY - Battery not charging - BQ24780S
                                        by Iherduleikgemz
                                        Hello everyone
                                        I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                                        I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                                        01-13-2025, 03:54 PM
                                      • cope
                                        Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                                        by cope
                                        I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                                        Some history:
                                        Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                                        As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                                        Now, with a new battery the system will start up and run off...
                                        05-13-2024, 09:40 AM
                                      • dr.thodt
                                        Asus GA401Q only working from battery
                                        by dr.thodt
                                        I have an Asus GA401Q which only works from battery power. That suggests the board is mainly fine.
                                        The battery status is 255%, also with a brand new battery.
                                        The BQ24800 was replaced since it showed signs that it was part of the problem, but possibly the battery was flat at that moment.
                                        If I insert the 19V adapter in the DC jack and measure the current sense resistor's voltage it fluctuates between 0V and 19.5V and the keyboard backlight flashes (probably because the battery is almost flat. It does the same when I run the laptop from battery).
                                        There's a...
                                        12-20-2024, 08:23 AM
