Medion mim2300 fan mod
  • senchire
    • Dec 2012
    • 190
    • Bosnia
    Hello folks, this laptop has some serious problems. Namely bios won't allow to change the speed of the fan.
    Well that would be fine except for 1 thing.
    The f****** bios only takes the CPU temp (which is <60) and turns down the fan speed. While the poor nvidia is cooking.
    So I had an idea, to destroy the white (regulation) wire, and short directly 5V to fans red wire. In theory that would be 100% fan speed non stop and the Medion wouldn't overheat (yes the dB would be insane but who cares headphones and rock it).
    What do you people think?
    P.S Just to say that no bios allowed me to change the fan speed.
  • artois7
    • Mar 2011
    • 159
    Re: Medion mim2300 fan mod
    Yep you shouldn't have a problem with this, other than premature fan wear. 5v from a USB line should do the trick.
    • senchire
      • Dec 2012
      • 190
      • Bosnia
      Yea but at least i would have usable laptop. But one thing triggers me. If i cut the white also known as the regulation wire, wouldnt i have non stop 5volts from the fan output circle.
        • 31094
        NO.
        5v fan, yes.
        but dont mess with the 3rd wire.
        it's not a regulator - it's a tacho feedback.
        if you cut it, the bios will think the fan has failed and shutdown the machine.
        • dj_ricoh
          • 2073
          yesterday i try to write about it and the notebook from work keep crashing. stupid mac
          nvm
          the 3rd wire usually white or yelllow its 3.3v
          when its 3.3v its on 100% spin. to lower the speed it lowers the voltage.
          you need to do some testing and see how much voltage is when its off middle and so on.
          i saw a mod on ytube when they use a switch to put the fan at 50% and 100% ofc by a resistor. it will not be so hard actually see how much you need for this so 5v on the 3rd wire?
          HELL NO!
          p.s. if you want 100% just connect a 3.3v from a fet and your good to go. ofc see witch one its on after power button its press
          • senchire
            • Dec 2012
            • 190
            • Bosnia
            dj_ricoh that is what I was going to do, I already changed the whole circuit (2 fets, 1 diode and 1 capacitor) to make it work.
            I was going to bypass the reduction trough the line and get it to the source (in this case its 4.57V) and let it run.
            Of course I'll try with a Bios mod, i asked the guys to do it at bios-mods and see will it fix this case.
            This laptop ain't to bad, just bad put together. The white line isn't the one that is generating the impulse to let the laptop know is the fan there or not ( i tested it on a spare fan its the same). So all in all, I can bypass the fet reduction and put it at the source or with some isolation from the usb port get the 5V and let it spin like a crazy muchaho.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Or you can do a more elegant solution - trick the fan controller to crank up the speed at a lower temperature by changing a resistor. Do you have a schematic?
              You can also undervolt the GPU which will make it run LOTS cooler.
              A working TV? How boring!
              • senchire
                • Dec 2012
                • 190
                • Bosnia
                Well regarding the resistor, sure thing but I will need some kind of explanation on that one (never moded that way just lets say the "brute way").
                Undervolt the GPU (like you did on the dv9000) or you think just with SW?
                The laptop is fresh reballed, but the temps are killing my eyes. No schematic I had to pay 15$ for them and saw no reason what so ever.
                By making it run cooler (the GPU), would make the laptop actually like it was meant to be. If you have some toughts how to do it, I am ready to take any DIY on it .
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  It isn't doable by software, it'll have to be a hardware mod. Yes, just like i did with the dv9000 (that i'm posting from right now).
                  If you can post some clear pictures of the board, both front and back, i'll try to help you. A schematic would be helpful but not absolutely required, as we can find all needed information in the datasheet of the controller used for gpu vcore.
                  • senchire
                    • Dec 2012
                    • 190
                    • Bosnia
                    Ok here is the front, later I'll post (when i take it apart). If you need clearer pictures tell me .
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      I need to know the part numbers of the two multi-pin ICs located above the GPU. U513 and U516 if i see well. By the looks of it U516 seems to be the PWM controller for the vcore supply, but i can't be 100% sure until you post the part numbers.
                      • senchire
                        • Dec 2012
                        • 190
                        • Bosnia
                        U516 = P2231TF C1, U-FN77A, L-07402
                        U513 isn't located near the GPU i need to open it.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          P2231 = TPS2231, which is an ExpressCard power controller. So it's not what we are looking for. The controller for the GPU Vcore may be on the other side of the board.
                          • senchire
                            • Dec 2012
                            • 190
                            • Bosnia
                            Just got an bios update from bios-mods, installed and he enabled CPU thermal configuration (sadly not even that is able to drive the fan).
                            I'll post pics in few minutes from both sides and details from U513.
                            • senchire
                              • Dec 2012
                              • 190
                              • Bosnia
                              Under the GPU is the following picture, and there we have bunch of capacitors. Since i don't have a schematic and got no clue what to look for I'll just post it and await some response when you have time .
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                The pictures aren't much help without part numbers, sorry.
                                • senchire
                                  • Dec 2012
                                  • 190
                                  • Bosnia
                                  In the end I've cut the yellow/white wire and the red (+) and put some straight 5V to the fan. Works a bit loud but hey an 8600GS is now on 50C idle and around 70C on load. The cpu is also under 55C under prime95.
                                  So for a temporary solution not bad.
                                  • dj_ricoh
                                    • 2073
                                    the white wire needs max 3.3v not 5v.
                                    you could have taken the 3.3v from anywhere
                                    nvm I hope it last and your happy
                                    • senchire
                                      • Dec 2012
                                      • 190
                                      • Bosnia
                                      The white (in my case yellow) isn't needed at all so its cut off. I only gave the red wire constant 5V for 100% spin.
                                      • MarkusMcFly
                                        • Feb 2015
                                        • 4
                                        Hi Senchire. I also tried the same BIOS mod. It doesn't fix the low fan speed. Can you please send some pictures that show how you fix it?
                                        • BlackBeetle
                                          MEDION AKOYA S15450 MD 63650 MSN: 30030203
                                          by BlackBeetle
                                          Hello, I have a problem with a Medion notebook.
                                          https://www.medion.com/de/service/pr...etail/30030203
                                          MEDION AKOYA S15450 (MD 63650) A-DE N MSN: 3003 0203 with Windows 10 64x
                                          The keyboard makes random entries and I don't seem to be the only one. Someone on this board has the same problem. I had BIOS version 207 installed and the BIOS version that Medion Support offers here as 209.
                                          https://community.medion.com/t5/Note.../104097/page/2
                                          Bios Version...
                                          08-09-2024, 05:50 PM
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                          MEDION AKOYA P5136 D AKOYA i5-6400 Specification for Upgrade or Repair
                                          This specification for the MEDION AKOYA P5136 D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA P5136 D boardview and AKOYA P5136 D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                          09-12-2024, 01:58 PM
                                          MEDION AKOYA P62006 AKOYA i7-8700 Specification for Upgrade or Repair
                                          This specification for the MEDION AKOYA P62006 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA P62006 boardview and AKOYA P62006 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                          MEDION ERAZER P66014 ERAZER i5-8400 Specification for Upgrade or Repair
                                          This specification for the MEDION ERAZER P66014 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ERAZER P66014 boardview and ERAZER P66014 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
