Toshiba L670 power problem
  • elerepair
    • Sep 2013
    • 10
    • Iceland
    Hello folks!
    So - I have this Toshiba L670 with a power problem. Laptop came in with corrupt BIOS, reflashed BIOS, laptop booted fine, and eventually it came in for repair again.
    Symptoms - AC only - Adapter light ON, when trying to power up - Power led blinks, and it resets to beginning.
    With battery and AC - sometimes it powers up, eventually shuts down due to battery being empty (Bat led blinks, and beeps. !! charger still connected!!)
    Scope measurements -- everything is fine til VIN is converted to B+ (schematic page 36 (S:36)
    VIN is nice straight 19.1V, but after 3 resistors it starts to oscillate. (*)
    +5VALW and +3VALW is present.
    when power button is ðressed - B+ drops down to 0 and resets.
    I cannot find the problem. Is the "PU6" (S:39) defective, shorting something out, or the problem is somewhere else ? Any help ?
    (*) --- I could try to take pics of my scope, if that helps.
    Thanks in advance!
    P.S. -- this mobo has BIOS and EC, as far as I know, is that right ?
    If so -- where to get dump for EC ?
  • elerepair
    • Sep 2013
    • 10
    • Iceland
    Re: Toshiba L670 power problem
    nobody?
    • alihomee
      • Dec 2012
      • 1594
      • malaysia
      check ec chip for voltages and also on battery connector
      • ravi_1617
        YY Solutions
        • Jan 2012
        • 348
        • India
        plug charger and charge battery fully in off condition laptop,then disconnect charger & run on battery only .see what happens
        • atsio
          • Oct 2013
          • 819
          • Greece
          Probably problem with charger circuitry.
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 348
            • India
            is it working fine in battery power.If yes then its NEC TOKINE problem
            • atsio
              • Oct 2013
              • 819
              • Greece
              That's a compal board, not an Inventec, where you usually can find the Nec Tokin.
              • dj_ricoh
                • 2073
                find pu5 and post the values from there. ISL6251 AHAZ
                with charger and battery
                with charger without battery
                only with battery.
                • elerepair
                  • Sep 2013
                  • 10
                  • Iceland
                  only with battery.
                  AC only:
                  19=15.7V
                  20=15.5V
                  22=1.5V
                  (rest is mV or 0)
                  AC + BATT
                  1=5.11V
                  2=5V
                  3=2.89V
                  5=5V
                  6=5V
                  8=2.3V
                  10=0.5V
                  11=0.6V
                  15=5.1V
                  16=4.7V
                  17=4.7V
                  18=3.5V
                  19=11.3V
                  20=11.3V
                  21=3.5V
                  22=3.5V
                  24=11.3V
                  BATT pin -- 3.5V
                  as per schem -- PQ17 -- AO4466. board has AO9636
                  but has 11.4V as on charger circuit.
                  • elerepair
                    • Sep 2013
                    • 10
                    • Iceland
                    looks to me that charger circuit is working fine. low voltage might been due to shitty battery.
                    Will check EC when I get back home.
                    and whats up with B+ ? on scope it looks like normal DC voltage, but has a bump down every second or so. and when Button is pressed it drops dramatically ?
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      Originally posted by elerepair
                      AC only:
                      19=15.7V
                      20=15.5V
                      22=1.5V
                      (rest is mV or 0)
                      Yes everything is fine
                      • dj_ricoh
                        • 2073
                        so DCIN its 0? do you think its ok?
                        dcin needs to be 19v with ac only and battery
                        • dj_ricoh
                          • 2073
                          check the fets near the dc connection and see if one its culprit!
                          • atsio
                            • Oct 2013
                            • 819
                            • Greece
                            That is what I am saying in my reply. The donkey is dead and they are trying to resurrect it. Problem in charger circuit.
                            • elerepair
                              • Sep 2013
                              • 10
                              • Iceland
                              yeah -- DCIN is 0v as it's only charger. And PQ11 is off.
                              I get 16V on PQ11 without battery -- and it drops down to 10V with battery.
                              What I'm concerned of - is the B+
                              check image for more.
                              is there a short in volt rails ?
                              • fddizon
                                • Sep 2011
                                • 555
                                • Philippines
                                could be. check b+ vs grnd
                                • theone111
                                  by theone111
                                  3. Problem: TV shuts down
                                  07-22-2024, 10:36 AM
                                • Duranitron
                                  Asus x512dk rev 2.1 power on problem
                                  by Duranitron
                                  When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                  Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                  11-26-2024, 10:22 PM
                                • EazyBone
                                  LG OLED55C9PUA power problem
                                  by EazyBone
                                  Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                                  Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                                  I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                                  The power supply to t con is different story.
                                  This...
                                  06-23-2023, 07:43 AM
                                • Dr.d
                                  Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                  by Dr.d
                                  I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                  Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                  04-05-2024, 11:48 AM
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
