Toshiba L670 power problem
    Hello folks!
    So - I have this Toshiba L670 with a power problem. Laptop came in with corrupt BIOS, reflashed BIOS, laptop booted fine, and eventually it came in for repair again.
    Symptoms - AC only - Adapter light ON, when trying to power up - Power led blinks, and it resets to beginning.
    With battery and AC - sometimes it powers up, eventually shuts down due to battery being empty (Bat led blinks, and beeps. !! charger still connected!!)
    Scope measurements -- everything is fine til VIN is converted to B+ (schematic page 36 (S:36)
    VIN is nice straight 19.1V, but after 3 resistors it starts to oscillate. (*)
    +5VALW and +3VALW is present.
    when power button is ðressed - B+ drops down to 0 and resets.
    I cannot find the problem. Is the "PU6" (S:39) defective, shorting something out, or the problem is somewhere else ? Any help ?
    (*) --- I could try to take pics of my scope, if that helps.
    Thanks in advance!
    P.S. -- this mobo has BIOS and EC, as far as I know, is that right ?
    If so -- where to get dump for EC ?
    Re: Toshiba L670 power problem
    nobody?
      check ec chip for voltages and also on battery connector
        plug charger and charge battery fully in off condition laptop,then disconnect charger & run on battery only .see what happens
          Probably problem with charger circuitry.
            is it working fine in battery power.If yes then its NEC TOKINE problem
              That's a compal board, not an Inventec, where you usually can find the Nec Tokin.
                find pu5 and post the values from there. ISL6251 AHAZ
                with charger and battery
                with charger without battery
                only with battery.
                  only with battery.
                  AC only:
                  19=15.7V
                  20=15.5V
                  22=1.5V
                  (rest is mV or 0)
                  AC + BATT
                  1=5.11V
                  2=5V
                  3=2.89V
                  5=5V
                  6=5V
                  8=2.3V
                  10=0.5V
                  11=0.6V
                  15=5.1V
                  16=4.7V
                  17=4.7V
                  18=3.5V
                  19=11.3V
                  20=11.3V
                  21=3.5V
                  22=3.5V
                  24=11.3V
                  BATT pin -- 3.5V
                  as per schem -- PQ17 -- AO4466. board has AO9636
                  but has 11.4V as on charger circuit.
                    looks to me that charger circuit is working fine. low voltage might been due to shitty battery.
                    Will check EC when I get back home.
                    and whats up with B+ ? on scope it looks like normal DC voltage, but has a bump down every second or so. and when Button is pressed it drops dramatically ?
                      Originally posted by elerepair View Post
                      AC only:
                      19=15.7V
                      20=15.5V
                      22=1.5V
                      (rest is mV or 0)
                      Yes everything is fine
                        so DCIN its 0? do you think its ok?
                        dcin needs to be 19v with ac only and battery
                          check the fets near the dc connection and see if one its culprit!
                            That is what I am saying in my reply. The donkey is dead and they are trying to resurrect it. Problem in charger circuit.
                              yeah -- DCIN is 0v as it's only charger. And PQ11 is off.
                              I get 16V on PQ11 without battery -- and it drops down to 10V with battery.
                              What I'm concerned of - is the B+
                              check image for more.
                              is there a short in volt rails ?
                                could be. check b+ vs grnd
