A2179 PPBUS_G3H low
  • Gueric
    • Feb 2025
    • 62
    • France
    A2179 PPBUS_G3H low
    Hey mon2. I’ve got another crazy case for you that never happened to me before.
    A2179 board, PPBUS_G3H short, 2 ohms.
    injected voltage, 1V 5A limit, 200mA draw.
    decided to increase to 2v, amperage draw instantly dropped to a few mA.
    the resistance of the rail actually went from 2 ohm to 100 after that, and PPBUS went from 0mV to 700mV.
    checked the resistance of the 4 current sensing resistors around the ISL, all fine. Removed the ISL, went from 100 to 160 ohm.
    Replaced it, still 160 ohm.
    Removed the 2 ISL mosfets. Still the same resistance. Replaced them both, still nothing.
    Replaced the ISL AGAIN, went to 220 ohm.
    PPBUS went from 700mv to 900mv.
    im really confused now.
    Also, PPDCIN_G3H is 5v as expected.
  • mon2
    • Dec 2019
    • 14047
    Hey. What is the 820-**** # you are referencing?
    Remove F7000 (for now).
    Remove all power. Meter in resistance mode. Measure the resistance between CHGR_CSIR_P and CHGR_CSIR_N. You can measure using the meter tips @ C7021 and C7022.
    • Gueric
      • Feb 2025
      • 62
      • France
      mon2 I'm talking about the 820-01958 2020 Intel MacBook Air.
      Remove F7000? the fuse that connects PPVBAT_G3H_FUSE and PPVBAT_G3H_CONN ?
      Regarding the resistance measurement between CHGR_CSIR_P and CHGR_CSIR_N, I measured 2.6 ohm.
      • mon2
        • Dec 2019
        • 14047
        Resistance is fine.
        Yes on the F7000 fuse.
        Measure the voltage to ground of VDDA and also VDDP.
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          if u have a thermal camera would be much easier to spot where the problem is.... also sometimes a caps get shorted only when a certain of voltage is appikied, with all the risks that it give...
          • Gueric
            • Feb 2025
            • 62
            • France
            Hey mon2 I’ve found a crazy technique to find PPBUS shorts.
            I removed 2 current sensing resistors, splitting PPBUS_G3H_SPKRL and PPBUS_G3H in half.
            Also another to separate PPBUS_HS_CPU from PPBUS_G3H.
            I now know the shorted part of PPBUS is PPBUS_HS_CPU.
            PPVIN_G3H_P1V1_S3
            is also 200 ohms, since it's another name for PPBUS_HS_CPU but I don't wanna remove its current sensing resistor yet.
            To remind you about the issue a little, resistance was at first 0.0 ohms, and went to 200 after I went from 1v to 2v while injecting.
            Also, I probed L7210, L7220 and L7230 in diode mode, and the readings are perfect according to OpenBoardData (0.106)
            How would you find the short at such high resistance ? Do you think the CPU could be cooked ?
            I don't have a thermal cam btw (sadly)
            thanks
            • mon2
              • Dec 2019
              • 14047
              What is the exact resistance to ground of PPBUS_HS_CPU in ohms @ C7210 (pin 1 = +)?
              • Gueric
                • Feb 2025
                • 62
                • France
                mon2 it's precisely 203,4 ohms on pin 1 of C7210.
                • mon2
                  • Dec 2019
                  • 14047
                  Measure the resistance from C7210 to L7210​. If this is ~0R ohms, then the high side mosfet of the regulator @ U7210 has leaked and yes then the CPU is cooked from this high voltage rail.
                  Repeat to test the resistance onto the other same CPU power rails @ L7220 and L7230.
                  • Gueric
                    • Feb 2025
                    • 62
                    • France
                    So I just checked mon2, and resistance between C7213 ( a PPBUS_HS_CPU cap just below U7210) and L7210, L7220 and L7230 is slightly below 300 ohms.
                    • mon2
                      • Dec 2019
                      • 14047
                      Test resistance between C7213 & L7400.
                      • Gueric
                        • Feb 2025
                        • 62
                        • France
                        mon2 it’s somewhere around 600 ohms.
                        • mon2
                          • Dec 2019
                          • 14047
                          This is a tough one. I think that you will have to remove each current sense resistor between the CPU / PCH and each of the regulators, one at a time to determine which side is with the short. Test the resistance after each such part is removed - keep track of the part and their locations. As before, you are attempting to isolate the sections of the circuit.
                          • Gueric
                            • Feb 2025
                            • 62
                            • France
                            mon2 could you explain a little further ? I know where those 3 regulators are, just next to the 3 big inductors, but there are hundreds of pads under the CPU and so many different lines for the CPU/PCH that I'm a bit lost on finding those current sensing resistors.
                            Also, there's one chip that PPBUS_HS_CPU passes through, U7700. and there's also a mosfet fed by PPVIN_G3H_P1V1_S3 (another name of PPBUS_HS_CPU) that's obviously also 200 ohms.
                            • mon2
                              • Dec 2019
                              • 14047
                              Every switching power supply will have a current sense loop to monitor the amount of current being sinked by the load.
                              For example, for L7400 it is current sense resistor @ R7430.
                              For L7210 it is R7210, etc. Albeit a pain, suggest to flux and remove each of these resistors to isolate the producer (regulator) and the consumer (CPU) sides of the power rail. Be sure to keep track of their placement orientation (they can get funky on their SMD pads / shapes so orientation is important). Do not mix up the parts. Not a fun exercise but needs to be done with hopes to hunt for the shorted part.
                              • Gueric
                                • Feb 2025
                                • 62
                                • France
                                mon2 okay I think I get it. So removing the 3 current sensing resistors (R7210, R7220, R7230) would help making sure it's not the CPU/PCH that's shorted internally? because upon checking PPVCC_S0_CPU was not shorted and diode readings were fine.
                                But that wouldn't help directly with the PPBUS_HS_CPU short would it ? There are a few chips that PPBUS_HS_CPU passes through, obviously those 3 regulators, but also U7700, U7100 and Q8100.
                                Thanks for all your help again.
                                • Gueric
                                  • Feb 2025
                                  • 62
                                  • France
                                  I've just removed the high side mosfet to try and see (U7210) and the short is still present on PPBUS_HS_CPU. I also removed R7101 to cut off the power to U7100 and same result, short still there.
                                  mon2
                                  Edit : I actually went ahead and removed all 4 regulators, nothing's changed. resistance has dropped to 200 ohms instead of 230.
                                  • Gueric
                                    • Feb 2025
                                    • 62
                                    • France
                                    I just also removed U7700. short still the same. 200 ohm on PPBUS_HS_CPU. I'm fully lost now
                                    • Gueric
                                      • Feb 2025
                                      • 62
                                      • France
                                      from my understanding there is one single big component left on PPBUS_HS_CPU and it's Q8100.
                                      I also haven't removed the 4 current sensing resistors. just the 4 regulators.
                                      • Gueric
                                        • Feb 2025
                                        • 62
                                        • France
                                        hey mon2 i found that short by injecting voltage again. i had to step up to 3v for it to show. small cap drawing 2v at 5 amps, literally smoking. @C7401. now i gotta put every component back on and pray. By the way, do you know if SW6955 if compulsory for the board to boot? i think i damaged it while removing Q8100. its SYS_DETECT and GND.
                                        • cind12
                                          GTX 1080 TI Gigabyte Aorus low resistance on vmem
                                          by cind12
                                          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                                          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                                          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                                          Resistance on 12V 4K ohms (Power present when on)
                                          Resistance on 12V PEX 4K ohms...
                                          12-08-2023, 09:09 AM
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                        • Jane
                                          What is the lowest acceptable resistance on a coil without considering a short on PCB
                                          by Jane
                                          I have Asus FA506 ( board DA0BKXMB8D0 Rev: D). Can you please roughly indicate what the lowest resistance I should measure on a coil? I know that a low resistance is allowed on coils in CPU or graphic circuits but can you provide acceptable values of resistance?
                                          Thank you.
                                          02-27-2024, 01:42 PM
                                        • loopster
                                          645 G9 with Ryzen 5 PRO 5675U | Resistance to ground of CPU?
                                          by loopster
                                          Hello everyone, I have a 645 G9 here with a Ryzen 5 PRO 5675U.
                                          This board has a blown inductor component above the driver chip to the CPU coil, and I am wondering whether the CPU is shorted/dead.
                                          Could anyone please measure the resistance to ground on the leftmost coil/inductor to the CPU?
                                          My resistance value is 2.2 Ohms, which doesn't look good to me.
                                          Thanks to everyone willing to give a value.​
                                          06-05-2025, 02:33 PM
                                        • CG2
                                          Janome DC3050 Sewing Machine Pedal Resistance
                                          by CG2
                                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                          04-14-2023, 07:53 AM
