VPCEC3L1E battery problem
  • lefos
    • Nov 2013
    • 321
    • Greece
    Hello everybody,
    I wanted your help with this one.
    Powers on everything works ok except battery charging. If you install its battery (tried with new working checked with other) the charging light blinks constantly.
    The motherboard model is mbx-225. I have found that PQ2 is shorted. After changing it the laptop doesn't power on, only if you put back the shorted one.
    Also changed the bd24753a
    Any ideas on this one please?
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    Re: VPCEC3L1E battery problem
    well its not turning up because OCP OVP circuits are blooking the mosfet to pass from drain to source .
    You must chek carefuly all mosfet on the charging circuit , and look also for the 3 leg mosfet , they are pain in the ass in OCP OVP circuit
    • NConstantinou
      LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
      by NConstantinou
      Dear all,
      i have the above laptop which had a problem with battery. i replaced it with a compatible one..
      the laptop DOES NOT POWER ON..
      with it old battery it does power on.
      i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
      when i shutdown the laptop does not power on.
      does anyone have any solution!
      when is not power on the usb c voltage tester shows 5v 1.3A
      when i disconnect battery and power on and then connect battery the tester...
      12-10-2024, 04:52 AM
    • mferna14
      MacBook Air A2681 battery problem after Screen Replacement
      by mferna14
      Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
      12-06-2024, 08:10 PM
    • HTR-Informatique
      by HTR-Informatique
      02-09-2025, 06:51 AM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • huzo
      HP ELITE X2 1013 G3 weird battery issue
      by huzo
      Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
      01-31-2025, 12:09 AM
