A2337 820-02016-A Failing DFU mode
  • TimScrawn
    • Dec 2021
    • 20
    • United Kingdom
    I have a very strange issue here. Customer was using Mac one day and stopped working when they went to use it the next day. I plugged it into my amp meter and I got 5v at 0.10amp.
    Checked all rails:
    PPBUS_AON: 12,3 V
    PP3V8: 3.79v
    PP3v3_AON: 3.29v
    PPDCIN_AON_CHGR_R: 5 V
    The very strange part of the issue is that I left the Mac on one side for a day, came back to it and reconnected everything. Connected the DFU cable to a WS machine and connected the charger. The Mac then booted to the login screen? I then logged in and because I was after the data, I went to go connect up an external drive to backup on to and disconnected the charger cable and not the DFU cable. Mac shutdown and has not powered up since... (Big mistake). Really struggling to figure out what is causing the issue.
    DFU revive keeps giving error - 4014
    I have used a donor icloud locked board and it works just fine in the housing with the battery charged to 50%
    No liquid damage or history of repair. Board is clean.
  • mon2
    • Dec 2019
    • 14685
    4014 is NAND related. Measure the voltage to ground of the NAND power rails. If they are absent, remove all power and measure their resistance to ground of each.
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      🛠 Original Issue
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • Adogabriel100
      where to get trusted CD3217. Problem with A2337 Macbook Air
      by Adogabriel100
      Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
      The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
      09-06-2024, 12:06 PM
    • soeren
      A2337 - Camara doesn't work
      by soeren
      I have replaced the display on my A2337 and I believe that during the change the battery connector was re-connected to the logic board and therefore I now have a non-working camera in my A2337 laptop.
      After the problem occurred, the camera was no longer detected and True Tone didn't work. I replaced the eDP flex cable (display connector) and now the camera is detected and True Tone works again.
      The problem is that when I open Facetime, for example, the green camera LED does not light up and the camera image remains black. In the end I get an error message. Does anyone...
      08-23-2024, 09:02 AM
    • slimmy182
      MacBook Air M1 A2337 820-02016 not booting, taking 5V 0.42A and 2.173W
      by slimmy182
      Hello, a friend give me this M1 Mac Air, he said that it simply stop working. Apple preventive is replacing motherboard.
      Model is MacBook Air M1 A2337, logic 820-02016, not booting, and taking 5V 0.42A and consuming 2.173W.
      Once disassembled is very clean, no water damage at all. Visual ispection reveal no visible problem. Flir camera point to two hot point:
      C81DC PP3V8_AON_VDDMAIN
      And
      Q5800
      What should I test as next step?
      Thank you very much!
      02-01-2024, 01:08 PM
    • todordm
      Macbook A2338 / A2337 - Replace SSD
      by todordm
      There are a lot of Video Tutorials how the SSD of A2338 or A2337 can be upgraded. Normally they say you can order the bigger SSD chips (0 and 1) from China. But as far as I understand you can take the SSD chips of one A2337/A2338 and install on another, put to DFU mode, do the recovery, reinstall etc... I tried that several times (tried to upgrade 256GB to 512Gb, then to 1TB, then to another 256Gb)... nothing worked. So my question to the community is: can I just take the SSD chips from one A2338 and intall them on another A2338 (taking care of course of the 0 and 1 positions)? Or I have always...
      01-17-2024, 03:55 AM
