Lenovo G40-80 ACLU3 ACLU4 NM A362 not charging
  • G_sene
    • Jul 2023
    • 76
    • Brasil
    Hi, everyone.
    I have this notebook that won't charge.
    In Windows, the charger icon doesn't appear on the battery, but the charger turns on the notebook normally.
    PU301:
    Pin 5 (ACOK) - 5.97v
    Pin 6 (ACDET) - 1.83v (should have 2.6)
    Pin 16 (REGN) - 6v
    PQ308 has no gate voltage, so it doesn't drive PQ309 low
    With the battery connected, its voltage goes the reverse way to the jack, having 14v and not 20v:
    PQ301 e PQ302
    Pinos 1,2,3 14v
    Pino 4 5v
    Pinos 5,6,7,8 com 14v
    Without battery:
    PQ301 e PQ302
    Pinos 1, 2 e 3 = 20v
    Pino 4 = 9v
    Pinos 5, 6, 7 e 8 = 20v
  • mon2
    • Dec 2019
    • 14681
    Yes.
    Check the resistance of PR310 and PR311. Do so without power to the machine. Each should be close to the schematic values.
    • G_sene
      • Jul 2023
      • 76
      • Brasil
      Originally posted by mon2
      Yes.
      The PR310 has 214k, off the board it has 390k.
      The PR311 has 54.97k.
      • Sephir0th
        • Oct 2020
        • 1289
        Since the resistors appear to be in tolerance, another possibility would be a too low voltage at VIN (PR310 Pin 2) or the charging controller pulling ACDET low for some reason (faulty charging controller).
        Edit: missed the part with the reverse voltage. This is definitely not okay. Did you check PQ301 and PQ302 for being internal shorted? even if it is only partial.
        These Mosfets shouldn't be activated in battery mode by pulling the Gates low.(dunno whether you checked that with battery only). And from my understanding PQ303 (Bat-to-sys-Fet) and PQ309 (Charging high-side) should be checked too. Because obviously the battery is supplying the main power rail even though the charger is plugged. And it shouldn't be like that.
        FairRepair on YouTube
        • G_sene
          • Jul 2023
          • 76
          • Brasil
          I have no short in PQ301, PQ302, PQ309 and PQ303.
          • mon2
            • Dec 2019
            • 14681
            Connect only the battery.
            Measure the voltage to ground of:
            BATT_OUT
            PACIN
            Then connect also the adapter. Battery to be still connected. Repeat the above measurements. Post each value.
            • G_sene
              • Jul 2023
              • 76
              • Brasil
              BATT_OUT
              PACIN
              Battery connected:
              BATT_OUT - 0V (PQ996)
              PACIN - 2.05v (Only in PQ307. PQ308 and PQ998 has no voltage of PACIN)
              Adapter and battery:
              PACIN - 2.08v
              • mon2
                • Dec 2019
                • 14681
                Confirm the following...
                Review the mosfet @ PQ998B. It does not appear to be working.
                ACOK = ~6v (from post #1) -> then is the gate voltage for PQ998B so this mosfet should close and drive PACIN to a logic level of '0' when the power adapter is mated. PACIN is stuck @ ~2v. Confirm it.
                • G_sene
                  • Jul 2023
                  • 76
                  • Brasil
                  I just did a test.
                  I left the notebook off to see if it would charge, I hadn't tested this before.
                  It stayed off the charger for about 2 hours, with no charging indicator LED, just the white LED that blinked, stopped and blinked (in this loop).
                  It charged very little.
                  With the notebook on, I still don't see the icon of the charger connected.
                  Another detail.
                  I tried to get the change in the PACIN logic level on pin 3 of the PQ998: With battery and without charger - PACIN low With battery and with charger - PACIN low Only charger - high, but when I remove and put the charger back in it goes to low and goes up again.
                  • mon2
                    • Dec 2019
                    • 14681
                    Measure the voltage to ground of BATT_OUT with only the power adapter connected. You have already shared the other permutations in post # 7 for this signal.
                    • G_sene
                      • Jul 2023
                      • 76
                      • Brasil
                      BATT_OUT still has 0v in PQ996 (with power adapter).
                      • mon2
                        • Dec 2019
                        • 14681
                        Measure the voltage to ground of the following:
                        PU202A - pins 1, 2, 3
                        PQ996A - pins 1, 2, 6
                        PQ996B - pins 3, 4, 5
                        • G_sene
                          • Jul 2023
                          • 76
                          • Brasil
                          With power supply:
                          PU202A:
                          Pin 1 - 3.36v
                          Pin 2 - 1.68v
                          Pin 3 - 3.01v
                          PQ996A:
                          Pin 1 - 0v
                          Pin 2 - 3.38v
                          Pin 6 - 0v
                          PQ996B:
                          Pin 3 - 0v
                          Pin 4 - 0v
                          Pin 5 - 3.36v
                          With power supply and battery:
                          PU202A:
                          Pin 1 - 0v
                          Pin 2 - 1.68v
                          Pin 3 - 2.18v
                          PQ996A:
                          Pin 1 - 0.v
                          Pin 2 - 0v
                          Pin 6 - 0.008v
                          PQ996B:
                          Pin 3 - 0.08v
                          Pin 4 - 0v
                          Pin 5 - 0.004v
                          • mon2
                            • Dec 2019
                            • 14681
                            Confirm that PR223 is present and that there is a 3v3 voltage on the high side of this resistor. Otherwise, PQ996 appears to be defective.
                            These are 2N7002 mosfets and only if the gate voltage is a logic '1' should they conduct and pull the line to low = ground. These dual mosfets appear to be in the stuck ON state.
                            • G_sene
                              • Jul 2023
                              • 76
                              • Brasil
                              PR223 seems to be it. 3.38v on the circled side, and on the other side, which would be BATT_OUT, zeroed.
                              • mon2
                                • Dec 2019
                                • 14681
                                This means the mosfets are always pulling this line down. Flux and remove pq996. Then the signal line should be pulled to a logic ‘1’.
                                • G_sene
                                  • Jul 2023
                                  • 76
                                  • Brasil
                                  Signal line "BATT_OUT"?
                                  • mon2
                                    • Dec 2019
                                    • 14681
                                    Yes.
                                    • G_sene
                                      • Jul 2023
                                      • 76
                                      • Brasil
                                      Yes.
                                      PQ996 removed and not beeping (pin 3 BATT_OUT)
                                      3.3v arriving on pin 3 (BATT_OUT)
                                      • mon2
                                        • Dec 2019
                                        • 14681
                                        Connect only the battery and measure the voltage on PU202A
                                        pins 1, 2 and 3.
                                        No power adapter. What is the voltage on the battery?
                                        Also, the ACDET is not the proper voltage based on the adapter voltage and the shared resistor values for the voltage divider.
                                        Suggest to flux and remove PC316 which may be affecting this voltage. The resistor values look ok for now. What is the ACDET voltage after removing PC316? For this ACDET testing, place back the PQ996 component on the board.
