Lenovo G50-80 Not ON Charger (no led) but Battery OK (ACLU3/ACLU4 UMA NM-A362)
  • zakiyy
    • Jul 2012
    • 13
    • mauritius
    Lenovo G50-80 (ACLU3/ACLU4 UMA NM-A362) Rev 1.0
    With battery laptop work perfectly ! But with charger no power and not charging ! What can be the problem??
    Direct from Charger PIN no connect to laptop: 20.v
    PQ301 (4407A)
    Drain: 20v - 19v 17v fluctuating
    source: 19v - 18 -16v fluctuating
    Gain: 19v - 18 -16v fluctuating
    PQ302(4483a)
    Drain: 2.5v then 5 then 10v then 11v sometimes18 then again 2.5v again and again..
  • zakiyy
    • Jul 2012
    • 13
    • mauritius
    Re: Lenovo G50-80 Not ON Charger (no led) but Battery OK (ACLU3/ACLU4 UMA NM-A362)
    When remove PQ302(4483a)
    Drain pin - 0.886 stable
    Source PIN: 20v stable
    Gain pin: 5.05v Stable
    PQ301 (4407A)
    Drain: 20v
    source: 20v
    Gain: 5v stable
    When do Jumper the laptop does not power on !
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Start with usual steps .With no power try :
      Diode mode : measure PQ 301/302
      Diode mode at PR301 and at all coils to confirm if there's or no a short !.
      If no short to ground proceed to take voltages of PU301 :
      Pin 20/6/5/16
      UE1 :
      pin 72 = ADAPTER_ID voltae !
      https://www.badcaps.net/forum/troubl...a362-schematic
      • Sametbey
        • Jan 2021
        • 229
        • Turkey
        According to your voltage measurements, your PU301 and inlet mosfets are intact. Possible short circuit at the + B point at the exit or after. You can start check to PU904 or PU905 + 3v.
        I'm not happy to be so strong. because it's not humanly
        • zakiyy
          • Jul 2012
          • 13
          • mauritius
          Diode mode : measure PQ 301/302 - NO SHORT
          Diode mode at PR301 and at all coils to confirm if there's or no a short !. - NO SHORT
          Pin
          20: 20v
          6:2.5v
          5: ov
          16: 5.95v
          UE1 :
          pin 72 = ADAPTER_ID = 0v
          PLEASE NOTE
          is remove PQ302(4483a)
          • zakiyy
            • Jul 2012
            • 13
            • mauritius
            PU904 Short
            PL 303 SHORT.. even remove it still short on the PIN.. where can i find the fault !
            • Sametbey
              • Jan 2021
              • 229
              • Turkey
              You can remove the PU904 and determine which foot has a short circuit. ITE IO can short circuit over power jack from hinge fault. You can detect the heated part by giving the PJ303 a voltage starting from 1V. or PU904 from 5 pins
              • salawayon
                • Nov 2012
                • 578
                • philippines
                I got a dead NM-A361 board and no short circuit on it. with ff details so far,
                LENOVO G50-80_DISCRETE_NM-A361
                = PQ301_4407A
                PIN5678 = 19.7V
                PIN123 = 19.7V
                PIN4 = 19.52V
                = PQ302_4483A
                PIN5678 = 0.89V ***?
                PIN123 = 19.7V
                PIN4 = 19.52V
                = PU301_BQ737
                PIN5 = 0V
                PIN6 = 2.59V
                PIN16 = 6V
                PIN20 = 19.7V
                = UE1_IT8586E
                PIN72 = 0V
                tried already replacing the ff:
                = PQ302 twice
                = PU301
                = UE1
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  PQ307,PIN5 Voltage?? Remove PQ304 & PQ305 and measure PQ301,pin4 voltage. Why un-necessarily change so many components??
                  • salawayon
                    • Nov 2012
                    • 578
                    • philippines
                    = PQ307_K27
                    PIN1 = 0V
                    PIN2 = 3.28V
                    PIN3 = 0V
                    PIN4 = 0V
                    PIN5 = 3.28V
                    PIN6 = 0V
                    = PQ301_PIN4 = 19.52v without PQ304 and PQ305
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      PQ307 is working fine and so your voltage divider for PQ301 gate should've wokred but somehow not working. Remove PR303/307 and check resistance out of circuit. Do they match schematic values?? PQ301 is not shorted??
                      • salawayon
                        • Nov 2012
                        • 578
                        • philippines
                        * PQ301_AO4407A = had a very low resistance reading between DRAIN and SOURCE pins, just 26ohms only. had it replaced but still the same status (dead unit)
                        * PR303/PR307 = had it removed and values were the same with the schematics... after putting back both resistors with hotair, PQ302 pin5678 gives an output of 19.7v but after cleaning the flux it went back to 0.89v. so, i decided to reflow all resistors near PQ307 and PU301 and by luck it's now alive... but i noticed another problem, it shutdown after a few seconds after power ON when battery and charger were both attached. but sometimes it works normal with both battery and charger attached but it won't charged the battery. after using another charger a smell of burning component came out from the laptop. one AO4466 mosfet near the battery terminal got busted. unit is now in normal status after replacing the AO4466 mosfet.
                        thank you very much for your tutorials and time...
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          @salawayon, great to know you fixed it but keep your fingers crossed. Since it worked after applying heat it may begenuine cold solder but it can be a bad resistor/cap/ic nearby. So just observe the unit for next 7 days. If it survives a week or so, hopefully its fully fixed.
                          • Bartoloni
                            • Jul 2018
                            • 140
                            • Italy
                            i received today another laptop like this one.. with PU904 becoming Hot... the EC seems fine, not shorts on nearby capacitors and no short on center pin of power connector, injecting on pin 5 of the PU904 the CX20752 (digital audio amplifier) starts heating, can be nice to remove the audio IC ... but customer wan't pay for a motherboard repair
                            • motormayhem
                              Lenovo T460 Only Charges on One Charger
                              by motormayhem
                              Laptop Question
                              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                              05-12-2023, 01:46 PM
                              NVDC charger configuration...
                              11-05-2024, 03:28 PM
                            • flat-earther
                              how to prevent a connected charger from draining battery when not charging?
                              by flat-earther
                              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                              So the battery is backfeeding the charger and being drained.
                              How can I prevent...
                              08-07-2025, 01:04 PM
                            • flat-earther
                              ASUS X54H laptop thinks it's always charging even with charger unplugged
                              by flat-earther
                              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                              Windows also shows ''Plugged in'' when charger is not connected.
                              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                              If I let battery run out and say it has 3% Windows will...
                              06-24-2025, 09:32 AM
                            • Johndill
                              Dell Inspiron 7567 LA-D993P odd charger issue
                              by Johndill
                              Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                              There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                              I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                              Here are the tested scenarios:
                              1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                              2. With the laptop off, plug in charger (LED says on) & the front charging...
                              11-16-2022, 10:55 PM
