Lenovo G40-80 ACLU3 ACLU4 NM A362 not charging
  • G_sene
    • Jul 2023
    • 5
    • Brasil
    Hi, everyone.
    I have this notebook that won't charge.
    In Windows, the charger icon doesn't appear on the battery, but the charger turns on the notebook normally.
    PU301:
    Pin 5 (ACOK) - 5.97v
    Pin 6 (ACDET) - 1.83v (should have 2.6)
    Pin 16 (REGN) - 6v
    PQ308 has no gate voltage, so it doesn't drive PQ309 low
    With the battery connected, its voltage goes the reverse way to the jack, having 14v and not 20v:
    PQ301 e PQ302
    Pinos 1,2,3 14v
    Pino 4 5v
    Pinos 5,6,7,8 com 14v
    Without battery:
    PQ301 e PQ302
    Pinos 1, 2 e 3 = 20v
    Pino 4 = 9v
    Pinos 5, 6, 7 e 8 = 20v
  • mon2
    • Dec 2019
    • 13844
    Yes.
    Check the resistance of PR310 and PR311. Do so without power to the machine. Each should be close to the schematic values.
    • G_sene
      • Jul 2023
      • 5
      • Brasil
      Originally posted by mon2
      Yes.
      The PR310 has 214k, off the board it has 390k.
      The PR311 has 54.97k.
      • Sephir0th
        • Oct 2020
        • 1260
        Since the resistors appear to be in tolerance, another possibility would be a too low voltage at VIN (PR310 Pin 2) or the charging controller pulling ACDET low for some reason (faulty charging controller).
        Edit: missed the part with the reverse voltage. This is definitely not okay. Did you check PQ301 and PQ302 for being internal shorted? even if it is only partial.
        These Mosfets shouldn't be activated in battery mode by pulling the Gates low.(dunno whether you checked that with battery only). And from my understanding PQ303 (Bat-to-sys-Fet) and PQ309 (Charging high-side) should be checked too. Because obviously the battery is supplying the main power rail even though the charger is plugged. And it shouldn't be like that.
        FairRepair on YouTube
        • G_sene
          • Jul 2023
          • 5
          • Brasil
          I have no short in PQ301, PQ302, PQ309 and PQ303.
          • mon2
            • Dec 2019
            • 13844
            Connect only the battery.
            Measure the voltage to ground of:
            BATT_OUT
            PACIN
            Then connect also the adapter. Battery to be still connected. Repeat the above measurements. Post each value.
            • G_sene
              • Jul 2023
              • 5
              • Brasil
              BATT_OUT
              PACIN
              Battery connected:
              BATT_OUT - 0V (PQ996)
              PACIN - 2.05v (Only in PQ307. PQ308 and PQ998 has no voltage of PACIN)
              Adapter and battery:
              PACIN - 2.08v
              • mon2
                • Dec 2019
                • 13844
                Confirm the following...
                Review the mosfet @ PQ998B. It does not appear to be working.
                ACOK = ~6v (from post #1) -> then is the gate voltage for PQ998B so this mosfet should close and drive PACIN to a logic level of '0' when the power adapter is mated. PACIN is stuck @ ~2v. Confirm it.
