Anyone recognise this mosfet
  • irfan-1
    • Jan 2025
    • 30
    • United Kingdom
    Hiya does anyone know which mosfet this is? If so does anyone know where to find a replacement? As i need to get it replace but i have no idea where to find one,
    Thank you
  • mon2
    • Dec 2019
    • 13867
    Post more details of the motherboard; make; model. Inquiring minds want to know.
    • R_J
      • 9518
      Looks like it is a PE636BA UNIKC-Semi PDFN 3x3p
      • irfan-1
        • Jan 2025
        • 30
        • United Kingdom
        It's from HP OMEN 15-DH1005NA, motherboard, LA-j6622 (N18E)
        • Sephir0th
          • Oct 2020
          • 1261
          Most likely PE636BA
          FairRepair on YouTube
          • irfan-1
            • Jan 2025
            • 30
            • United Kingdom
            Thanks, i can't fix my laptop till i change this mosfit, if i find one will the number on the mosfit matter? Or just replace it with any PE636BA
            • irfan-1
              • Jan 2025
              • 30
              • United Kingdom
              Originally posted by Sephir0th
              Most likely PE636BA
              Hopefully i can find that somewhere to get my laptop up and running
              • mon2
                • Dec 2019
                • 13867
                You have many choices, including to use the one mentioned above.
                Found a similar schematic - see attached.
                Criteria:
                1) 3 x 3 smd size
                2) N-channel type
                3) handle the same or higher currents as the original (use the one in this shared schematic to review the datasheet - use it for reference)
                4) handle the same or higher voltages
                From where do you like to shop for parts? Digikey / mouser / RS Electronics ok? You are in the UK so you should also have access to Mobile Sentrix (UK branch).
                Lowest cost will be from Aliexpress but will take time for delivery.
                • irfan-1
                  • Jan 2025
                  • 30
                  • United Kingdom
                  Criteria:
                  1) 3 x 3 smd size
                  2) N-channel type
                  Thank you so much, yes am from UK but just starting learning to repair electronics items, for my laptop it's my first time that's why i didn't know where to buy them from
                  • mon2
                    • Dec 2019
                    • 13867
                    Here is a stock item at DK.
                    https://www.digikey.ca/en/products/d...IPknG1WLGMS2gA
                    * linked are Canadian $ prices. Change the currency to suit. DK has a fair shipping fee.
                    * this cross should work fine
                    Here is a link for Mobile Sentrix (UK) - this part should also be ok but has a lower current rating:
                    https://www.mobilesentrix.uk/cpu-mos...-n-channel-d-s
                    • irfan-1
                      • Jan 2025
                      • 30
                      • United Kingdom
                      Thank you for all your help
                      • irfan-1
                        • Jan 2025
                        • 30
                        • United Kingdom
                        Am just sending you a big picture so you can see what's around the mosfet itself so you know 100% sure it's the one you mentioned earlier
                        • Jane
                          How do you test MOSFET in laptops ?
                          by Jane
                          I tried to use this method:
                          Testing an N-channel MOSFET:
                          Step 1: Discharge the Gate (turn off the MOSFET)
                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                          Step 2: Charge the Gate (turn on the MOSFET)
                          Now, place the red probe on the Gate (G) and the black probe on the
                          09-27-2024, 03:31 AM
                        • Nooy
                          VGA MOSfet permanently shorted and loss of MOSfet pad
                          by Nooy
                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                          02-14-2024, 02:26 AM
                        • AppleLover123
                          Asus X712EA 3 volts after the first mosfet
                          by AppleLover123
                          Hey guys,
                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                          Now i thought something...
                          12-15-2024, 07:49 AM
                        • MicroSMD Lab
                          ASUS ROG Zephyrus GPU Mosfet repeat failure
                          by MicroSMD Lab
                          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                          01-10-2024, 06:36 AM
                        • Scotchmist
                          Asus GA502D keeps blowing mosfet
                          by Scotchmist
                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                          I have removed the mosfet and can run the laptop no problem
                          The MOSFET is FDPC5018SG
                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                          08-24-2024, 02:23 PM
