MacBook Air A1932 internet recovery loop
  • nikolayu
    • Feb 2021
    • 40
    I have A1932 that is going to internet recovery every time.
    i tried nvram and smc reset but it looks that MacBook is not reacting to that.
    i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
    keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
    also won’t open option to boot from usb device.
    and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
    did someone had similar issue?
  • bouch
    unlock macbook air A1932 2019
    by bouch
    hi
    i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
    i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
    i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
    have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
    I need help or information?
    Does anyone have the minat2 activator 1.4 software?
    Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
    Thank yo...
    03-12-2025, 10:14 AM
  • cheebster
    Macbook Air 2020 A2179 Internet Recovery and Battery Issues
    by cheebster
    Hello, i have a batch of 10 Macbook Pros A2179 bought from a Costco return wholesaler.
    The 10 of them show the exact same behavior;
    They auto power on, to internet recovery spinning globe, fans to 100%.
    Power consumption on USB-C port is 0.43a, shuts down as soon as unplugged. Battery doesn't charge at all. However, it boots to 20V on the Ampmeter.
    Based on their iBridge versions (4.x and 5.x) these were shelfed for a long time.
    All of them power on the same way; 100% fans, shut down as soon as they are unplugged. Removing...
    10-09-2024, 06:23 AM
  • conghuyms
    Macbook air m1 can't access the recovery options by pressing and holding the power button
    by conghuyms
    I have an M1 MacBook Air (A2337) 2020 that came in for water damage and will not turn on. Upon opening it, I saw that the audio board was severely corroded. I disconnected it, and the device started working.
    After that, I dealt with the issues on the audio board by removing the capacitors that were shorted to ground, and the device started working. However, I encountered another problem: I can't access the recovery options by pressing and holding the power button. I'm not sure if it's a hardware issue or if the recovery partition has been lost. Currently, the system's time isn't updating,...
    10-14-2024, 06:43 AM
  • No Lan
    [Macbook pro A1708] [Boot loop] [Trackpad ?]
    by No Lan
    Hey everyone,
    Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
    Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
    Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
    05-24-2025, 03:09 PM
  • TOMÁŠ
    MacBook Air A1932
    by TOMÁŠ
    Hi, I've never worked with a MacBook before, so I need some advice.
    I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
    05-20-2025, 11:19 AM
