MacBook A1708 820-00840-a speaker making strange noises
  • dbuergi
    • Jul 2024
    • 123
    • Deutschland
    i fixed a A1708 which was not working. Not its booting but the left speaker is making buzzing and sizzling noises. I added a short video to show it.
    https://www.dropbox.com/scl/fi/ju6v7...=lewlrdkh&dl=0
    I already reflowed the audio codec chips but that didn't help. Any ideas what to do?
  • mon2
    • Dec 2019
    • 14172
    Sounds like your fan is rubbing. Disconnect the fan connector and test again without the right side fan running.
    • dbuergi
      • Jul 2024
      • 123
      • Deutschland
      Hello mon2,
      will try it later but the sound comes right away when i Start the MacBook and doesn't come with speaker FLEX disconnected.
      • dbuergi
        • Jul 2024
        • 123
        • Deutschland
        Little update here. I found a short a U6460 removed the chip and it was gone. After replacing it with a donor i also found a short at U6440. Same game and now all shorts are gone and 1,8v are present but i still get no sound but the noises stopped. I also tried PRAM reset without any success.
        So maybe any other ideas? The fan is not the cause of any problem.
        • mon2
          • Dec 2019
          • 14172
          U6440 is a dainty WLCSP package. Soldering ok? Remove all power. Measure the ferrite bead L6440 in DIODE mode. Red meter probe to ground. Black meter probe on L6440.
          Repeat for L6441. Suggest to disconnect the speaker so that we get a measurement of the amplifier chip. You should have a voltage reading in diode mode. If OL, then the amplifier output is disconnected.
          • dbuergi
            • Jul 2024
            • 123
            • Deutschland
            L6440 and L6441 both show 0,6V.
            L6460 and L6461 also 0,6V.
            I reballed U6440 and U6460 and soldering back went without any problems.
            • mon2
              • Dec 2019
              • 14172
              At this point, do you have any sounds working from either speaker?
              Review, U6460, U6440, U6420, U6400 which are the audio amps.
              Also of importance is the audio codec @ U6200 which converts the audio streams for the logic board.
              Do check if the s/w is able to see this audio device in the hardware. BTW - are you able to hear any sounds with a headphone? BLE headphones? Assuming this to be ok.
              • dbuergi
                • Jul 2024
                • 123
                • Deutschland
                Sorry was a bit busy but had a moment today to look at this board again. 8409_I2C_SDA line only shows 8ohm so the problem ist somewhere between the parts you mentioned.
                Removing U6200 didn't help but i had no time to do anything else.
                • obelix24
                  Macbook Air a1932 only right speaker working
                  by obelix24
                  I just got one macbook air a1932 that is fullu working (no signs of liquid damage but there is strange issue that only right speaker is working (that one that is connected directly to audio board)
                  the other one is not working at all.
                  i've tried to replace left speaker 3x and still no sound, i've also replaced audio board but still the same.
                  Do you know what can cause this issue ?
                  10-30-2024, 01:31 AM
                • Gueric
                  MacBook Pro 2019 820-01700 Speaker amp issue.
                  by Gueric
                  I have this MacBook Pro on my bench that I have already fixed, hard short on a SSD rail, but it also has another issue. the right speaker sound is either earrape, muffled or absent. Left one works perfect. I have tried replacing it, nothing changed so I'm pretty sure the issue is either motherboard related or maybe software but I doubt that.
                  I don't how to troubleshoot speakers. Any help would be very much appreciated.
                  A refurbisher and a repair shop have already been inside the laptop but I'm pretty sure none of them tried to do any soldering on the board.
                  05-19-2025, 03:08 AM
                • EpicFix
                  MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
                  by EpicFix
                  Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
                  04-08-2025, 09:55 AM
                • 24gsm
                  MacBook Pro A1708 install macos fail
                  by 24gsm
                  hi to all
                  i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                  after enter to recovery and format hdd 1to .
                  after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                  can help please
                  Serial Number: FVFXP0U0HV2J
                  Config Code: HV2J
                  Find My Mac: OFF
                  04-16-2025, 03:57 AM
                • envym
                  MacBook Pro 2018 with Activation Lock
                  by envym
                  Hi everyone!
                  I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                  I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                  06-27-2025, 08:54 AM
