Dell Ispiron P102F, motherboard Wistron Mockingbird N AMD 19852-1
    Hi, I'm new to laptop repairing, but not new to electronics. I just opened a laptop a friend gave me (no power) , and I was hoping for shorted main power rail , a bad capacitor or a bad dc-in mosfet. Up until now I haven't found a short or something obviously burned, the dc-in mosfets seem to work ok, the + on the big capacitors close to the CPU have an OK resistance to ground (around 14-15ohm) but following this thread here I connected the motherboard to the power brick to check the voltages. I didn“t do a lot of poking around when I noticed that the CPU was rather hot (over 55-60C to the touch). I guess this is a bad sign, as I just plugged the dc-jack on the naked motherboard, so It shouldn't try to turn on and get the CPU hot.
    Checking again, the power brick starts consuming 7-8Watts of power when plugged into the motherboard after a few seconds. Is it normal for motherboards to turn on like that? I guess no as the control chip should turn off the power if it notices such a short...
    My question is is there something obvious I am missing, do motherboards just turn on by themselves like that when you plug them in???
    Thanks for your insights and patience
    PS To continue the story, I just plugged some connections back on the motherboard and it seemed to turn on now. I thought It would be some peripheral component that was shorted so I plugged things one by one and lo and behold everything seems to work fine this time around. For some background this laptop had its motherboard replaced by a "professional" Dell technician who came to my friends home and a few days later died. My friend complained to dell and they sent him a replacement laptop and never asked for the broken back. The dell technician was either very bored or it was his first time as the screws were in a bad shape (just philips screws) and the motherboard had scratches so bad close to the BIOS with a few revealed lines. That was my first concern but after testing and inspecting the scratches I found no broken continuity to the legs of the BIOS chip.
    So I don't know maybe it dies again, or the guy didn't properly placed something that was shorting or making the laptop unable to boot. Will let it run a bit to check...
    If you still have a similar story please share the issue you had because I kind of have a love-hate relationship to electronics that magically work after I touch them with my fingers
    Thanks for reading
    and cheers
      Newer motherboard's RTC circuit is inside backup battery-so when you remove the backup battery,its expected to turn on its own when adapter is connected due to RTC reset.
      Put the heatsink back and measure voltage on all coils.
        Thanks for that , last time I repaired a laptop mobo was when laptop mobos didn't look like mobile phones , so I got really surprised
        Turns out everything seems ok, I will torture the laptop now to see if something gives.....
