Hi, I'm new to laptop repairing, but not new to electronics. I just opened a laptop a friend gave me (no power) , and I was hoping for shorted main power rail , a bad capacitor or a bad dc-in mosfet. Up until now I haven't found a short or something obviously burned, the dc-in mosfets seem to work ok, the + on the big capacitors close to the CPU have an OK resistance to ground (around 14-15ohm) but following this thread here I connected the motherboard to the power brick to check the voltages. I didn´t do a lot of poking around when I noticed that the CPU was rather hot (over 55-60C to the touch). I guess this is a bad sign, as I just plugged the dc-jack on the naked motherboard, so It shouldn't try to turn on and get the CPU hot.
Checking again, the power brick starts consuming 7-8Watts of power when plugged into the motherboard after a few seconds. Is it normal for motherboards to turn on like that? I guess no as the control chip should turn off the power if it notices such a short...
My question is is there something obvious I am missing, do motherboards just turn on by themselves like that when you plug them in???
Thanks for your insights and patience
