MacBook Pro 2019 820-01700 Speaker amp issue.
  • Gueric
    • Feb 2025
    • 72
    • France
    I have this MacBook Pro on my bench that I have already fixed, hard short on a SSD rail, but it also has another issue. the right speaker sound is either earrape, muffled or absent. Left one works perfect. I have tried replacing it, nothing changed so I'm pretty sure the issue is either motherboard related or maybe software but I doubt that.
    I don't how to troubleshoot speakers. Any help would be very much appreciated.
    A refurbisher and a repair shop have already been inside the laptop but I'm pretty sure none of them tried to do any soldering on the board.
  • mon2
    • Dec 2019
    • 14691
    Does the right side speaker work on the left side?
    Not at my desk yet but hunt for the audio codec and amplifier linked to the right speaker. Confirm there is no damage in this region of the board.
    • Gueric
      • Feb 2025
      • 72
      • France
      hey mon2. good to see you. I haven't tried that but I tried replacing both speakers just to make sure and it was still causing the same random issues with both speakers. For some reason now the left one works normal.
      I also took a quick look at the 3 chips around the right speaker connector and nothing looks weird. no cracks, no weird colored caps, no corrosion.
      • mon2
        • Dec 2019
        • 14691
        Measure the voltage to ground of:
        I2C_SPKRAMP_R_SCL
        I2C_SPKRAMP_R_SDA
        U6560 - PP1V8_G3S
        U6560 may be defective and needs to be replaced.
        • Gueric
          • Feb 2025
          • 72
          • France
          mon2 Hey. I can't probe the 2 I2C lines because the only component on those lines is a minuscule resistor inside the T2 metal shield. I probed PP1V8_G3S and it's exactly 1V8 as expected, stable.
          How can I know which of the 3 speaker amp chips around the connector is defective ? do I go straight for U6560?
          Also, one of my 2020 Intel MacBook Air board has the exact same speaker amp chip. Will it work if I harvest the chip from this board ?
          • Gueric
            • Feb 2025
            • 72
            • France
            Also forgot to add that, but we're talking about the right side speaker right ? U6560 is on the left side (maybe its the chip that manages all the other and I lack knowledge)
            • Gueric
              • Feb 2025
              • 72
              • France
              ignore my previous message, I was distracted from work
              • mon2
                • Dec 2019
                • 14691
                Yes, to me U6560 is a suspect. The part is available on the market or from donor boards.
                See here:
                https://www.ebay.com/itm/335277989425
                Assuming here that the actual speaker itself is not damaged. Do inspect the cone, etc for possible liquid or being torn damage. Other than this, perhaps the driving amp is defective which will be U6560.
                • Gueric
                  • Feb 2025
                  • 72
                  • France
                  mon2 it would be very unlucky for both the original speaker and the remplacement one to be defective. I’ll replace all 3 chips just to make sure.
                  • Gueric
                    • Feb 2025
                    • 72
                    • France
                    Hey mon2 so I’ve replaced all 3 chips (not just U6560 just to make sure) and both speakers are now working. However a new issue appeared, causing both speakers to saturate a little in the highs, and a lot at high volume. What do you think could be the issue now ? The speakers themselves ? The other 3 chips ? I don’t know what to look for now
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      🛠 Original Issue
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • cheebster
                      MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
                      by cheebster
                      Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
                      Nand voltages are missing.
                      I've found no shorts at all so far, no signs of heat via thermal camera either.
                      PPBUS_G3H 12.31
                      PP3V3_G3H_RTC 3.387v
                      PP3V3_G3H 12.31v
                      PP2v5_NAND_SSD0 0v 58 ohms
                      PP2v5_NAND_SSD1 0v 57.8 ohms
                      PP1v8_SLPS2R 1.8v
                      PP1v1_SLPS2R 1.1v
                      P3V3_G3H_SOCPMU 3.37v
                      PP0V9_SLPDDR 0.9v...
                      10-11-2023, 11:31 AM
                    • bouch
                      unlock macbook air A1932 2019
                      by bouch
                      hi
                      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                      I need help or information?
                      Does anyone have the minat2 activator 1.4 software?
                      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                      Thank yo...
                      03-12-2025, 10:14 AM
                    • zklgfs
                      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                      by zklgfs
                      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                      08-11-2025, 02:14 PM
                    • Stephen
                      MacBook Pro 16" 2019 A2141 Issue (powers on)
                      by Stephen
                      Board powers on, holds charge it seems, track pad clicks, display is working etc. When trying to boot it turns itself off and then boots again and repeats. If it stays at GLOBE icon it will not turn off. Customer needs data, enabled THUNDERBOLT Mode, plugged in Thunderbolt cable, but error comes "THIS DISK CANNONT BE UNLOCKED DUE TO AN ERROR" I can't even input a password. Did a soft restore to retain data to see if it will solve any firmware issues. Nothing, I do not want to restore the computer because the customer needs the data, computer stays on completely when at Globe or...
                      12-06-2023, 03:10 PM
