Latitude 3301 not charge battery
  • dclass-pro
    • Dec 2022
    • 157
    • Italy
    Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
    I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
    I noticed 2 things:
    1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
    2) if I try to turn it on without the battery the notebook doesn't turn on.
    I checked the mosfets but they seem good.
    On PR4401 I have 19V and on ISL9538h pins I have this:
    Pin 17=19V
    Pin 18=5.1V
    Pin 19=3.2V
    Pin 20=0
    Pin 21=0.8
    Pin 22=0.8
    Pin 23=0
    Pin 24=3.2V
    What can I check?
    Schematic & boardview -> https://www.badcaps.net/forum/troubl...istron-18769-1
  • mon2
    • Dec 2019
    • 14116
    Pin 17=19V
    Pin 18=5.1V
    Pin 19=3.2V
    Double check these values.
    Pin 19 is ground.
    Pin 17 & 18 are the battery current sense pins so each should be close in the measurements. Otherwise, this current loop is broken.
    • dclass-pro
      • Dec 2022
      • 157
      • Italy
      my charger is a ISL9538h here is a demo photo of the pins
      • mon2
        • Dec 2019
        • 14116
        Pins 21 & 22 should not be low. Study the pull ups and pull up voltage.
        • dclass-pro
          • Dec 2022
          • 157
          • Italy
          the problem is that they come from the KBC but the KBC is not powered because on pin 5 I read 0.9V instead of 3V.
          • mon2
            • Dec 2019
            • 14116
            Which schematic are you referencing? Is it the one from your first post?
            Check the always on rails if the KBC is not being powered. Measure the resistance to ground of this power rail. Someone may be shorted.
            • dclass-pro
              • Dec 2022
              • 157
              • Italy
              yes exactly the diagram is the one in the first post, if I measure the resistance to ground it is on megaohms and if I connect the battery I have 3 volts on both lines.
              I can't understand why it doesn't generate the 3v to power the KBC​
              • mon2
                • Dec 2019
                • 14116
                Check the dual diode @ D20.
                Remove all power. Meter in diode mode. Red meter probe on pin # 1; black meter probe on pin # 3. Meter should conduct. Reverse the meter probes, the meter should block = OL.
                Repeat with pins # 2 & # 3. Post all measurements.
                • dclass-pro
                  • Dec 2022
                  • 157
                  • Italy
                  This is the schematic pag.25 I have, and on pin 3 of D2501 I have 3V but on the KBC I have no voltage
                  KBC is at page 24
                  • dclass-pro
                    • Dec 2022
                    • 157
                    • Italy
                    I noticed that between pin 1 and pin 7 I have about 20V
                    but between pin 1 and pin 4 PS_ID_R I have 0v
                    If I put black push on pin 4 and red tip on pin 7 I have 19v.
                    But is it correct?
                    I disconnected the charging connector and I have the same thing.​
                    • Sephir0th
                      • Oct 2020
                      • 1282
                      What did you mean with Pin 14 and 15 were shorted? To each other or to GND?
                      Also show pictures of your job.
                      FairRepair on YouTube
                      • dclass-pro
                        • Dec 2022
                        • 157
                        • Italy
                        they were shorted to ground and the problem was the ISL because I changed it and it was solved
                        • mon2
                          • Dec 2019
                          • 14116
                          This is appearing to be a text book PS_ID fault since pin #4 on the power adapter connector is @ 0v. Trace this back to the mosfet that will be in series with this PS_ID line. This 1-wire line is broken for the communication so the logic board assumes by default that the power adapter is too weak to power the board AND charge the battery. The logic board is very likely being throttled in speed AND the battery charging feature is disable. Your bios will also report this default power adapter detection.
                          • dclass-pro
                            • Dec 2022
                            • 157
                            • Italy
                            I didn't understand what to check, I noticed that on D4302 on pins 3 and 2 I find 0.6V
                            • mon2
                              • Dec 2019
                              • 14116
                              Post your exact schematic here. Unable to find anything like your posted schematic on page 25. Nothing comes up in searching for 'D2501'.
                              • dclass-pro
                                • Dec 2022
                                • 157
                                • Italy
                                this is at page 43
                                • mon2
                                  • Dec 2019
                                  • 14116
                                  Flux and remove the esd diode on the ps_id pin on the power adapter. Test again the voltage on this pin. Should be ~3v here else the MOSFET is likely damaged.
                                  • dclass-pro
                                    • Dec 2022
                                    • 157
                                    • Italy
                                    I removed the ESD dido but nothing changes, I also removed the Q4301 mosfet but on the PS_ID pin I always have 0V
                                    • dclass-pro
                                      • Dec 2022
                                      • 157
                                      • Italy
                                      "Test again the voltage on this pin. Should be ~3v here else the MOSFET is likely damaged."
                                      Between ground and PS_ID pin?​ have 0V
                                      • mon2
                                        • Dec 2019
                                        • 14116
                                        Test the voltage to ground on each pcb pad for Q4301. Q4301 needs to be present to pass through the 1-wire communication to the adapter. Otherwise, Q4301 needs to be bypassed but then the crowbar circuit created by Q4301 is no longer available. The purpose is that if there is a high enough voltage on this 1-wire PS_ID line, the Q4301 mosfet is triggered to prevent damage to the EC.
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
                                        • Klevjetack
                                          Charge a L19D3PDA battery externally from the laptop
                                          by Klevjetack
                                          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                          03-05-2024, 07:26 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
