Toshiba Satellite A300 display
  • innocentforeign
    innocentforeign
    • Jun 2013
    • 172
    • KSA
    hi friends
    i need some help yesterday i got a laptop Toshiba satellite a300 with display problem
    Toshiba logo coming and also display working fine in bios setup .
    but when exit from bios setup display still with some different colors
    you can see in pictures
    should i flash bios ?
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Toshiba Satellite A300 display
    If its freezing, Its likely to be the common nec/tokin capacitor cause.
    https://www.badcaps.net/forum/showthread.php?t=8991
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3577
      • slovakia
      very known issue of IGP, reflow it or reball it, but it can be even bad lcd cable
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Yes I agree. It looks like the common nec/tokin capacitor failure. I'm fairly sure it's NOT the IGP at fault.
        A working TV? How boring!
        • spleenharvester
          • Mar 2010
          • 902
          Tokin fault, this is what a CPU with not enough power looks like.
          Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
          • innocentforeign
            innocentforeign
            • Jun 2013
            • 172
            • KSA
            thanks all of you for help
            vga cable and lcd are ok i am sure 100%
            i replace the Nec tokin capacitor with 4x 330uf
            but problem still same
            • lefos
              • Nov 2013
              • 321
              • Greece
              Are you sure that all capacitors are soldered good?
              The laptop stucks or has just that line? On external monitor?
              • innocentforeign
                innocentforeign
                • Jun 2013
                • 172
                • KSA
                thanks for reply
                i am sure that all capacitors are soldered good and also add 2 capacitors of 220uf
                laptop stuck after Toshiba logo . same conduction on external display i also reflow the IGP but nothing change . i am also sure its freezing problem .
                • innocentforeign
                  innocentforeign
                  • Jun 2013
                  • 172
                  • KSA
                  friends any other Suggestion
                  • cyberhack
                    • Feb 2013
                    • 466
                    • Uk
                    ram?
                    • innocentforeign
                      innocentforeign
                      • Jun 2013
                      • 172
                      • KSA
                      also check with new one . same
                      • marcellodj
                        • Nov 2010
                        • 99
                        discrete boar or uma?
                        • lefos
                          • Nov 2013
                          • 321
                          • Greece
                          Silly but have you tried to remove the CMOS battery and leave it off for some seconds?
                          • innocentforeign
                            innocentforeign
                            • Jun 2013
                            • 172
                            • KSA
                            yes also try to remove cmos battery .
                            should i check another capacitor with different value?
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Tried with other RAM?
                              • innocentforeign
                                innocentforeign
                                • Jun 2013
                                • 172
                                • KSA
                                yes try with new Ram and also change processor nothing change
                                • dspok
                                  • Jan 2014
                                  • 553
                                  • Nepal
                                  did you also try other os? e.g. linux etc etc
                                  • spidey
                                    climbs
                                    • Dec 2012
                                    • 644
                                    • Cyprus
                                    add more caps and check cpu vcore voltage.
                                    • dycc
                                      Vision
                                      • Nov 2011
                                      • 625
                                      • Côte d'Ivoire
                                      another processor ??????????
                                      make sure also south-bridge is not becoming very hot while booting .
                                      post back all main voltage (cpu igp ram south-bridge )
                                      turn on an check if cpu or other main voltage is not flapping
                                      • innocentforeign
                                        innocentforeign
                                        • Jun 2013
                                        • 172
                                        • KSA
                                        finally solve it .
                                        add 6x 330uf and 2x 470uf capacitors also change one capacitor inside CPU socket . now, if i press power button laptop start after 15 second and working good .delay 15 second in startup can create any problem in future
                                        or its ok ?
                                        i am so thank full all of you for help special sir Spidey,
                                        • lanovey
                                          SF314-41 BIOS without internal display
                                          by lanovey
                                          Hello there,
                                          I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
                                          I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
                                          06-13-2025, 02:38 AM
                                        • carlo64
                                          Toshiba Satellite P20 BIOS
                                          by carlo64
                                          Hi, I'm looking for a different bios than the 210 (bios-s-p20-210win.zip found with google) for this laptop
                                          as this version seems to cause me pci conflict with the wireless card after the first reboot.
                                          Can you help me?
                                          Thanks!!!
                                          Carlo
                                          detail:
                                          TOSHIBA
                                          MODEL NAME:Satellite P20
                                          MOFRL NO. PSP20E-4G50V-IT/SP20-842
                                          P4 3.00Ghz/2X256/80G42/17WT/DS/LM
                                          SERIAL NO. 84324385K
                                          I84324385KSSP20E-4G50VITD​...
                                          10-22-2024, 05:13 AM
                                        • ladharimohamed2
                                          Need bios toshiba satellite pro r50-b-15j
                                          by ladharimohamed2
                                          I need bios for toshiba satellite pro r50-b-15j motherboard faebsy2
                                          i have tried this :
                                          but no power
                                          and i tried this
                                          the laptop worked but asked for a password
                                          i have tried many with same motherboard name wich is FAEBSY2 A5A003954010 A but the laptop didnt turn on (no lights, no fan spinning)
                                          i have attached my original bios wich has been corrupted after a windows update (turn on but black screen)
                                          if any have the bios for the exact model name will be great "toshiba satellite pro r50-b-15j"...
                                          04-18-2024, 07:54 AM
                                          Toshiba Satellite A300 A300-14S Laptop Schematic
                                          Quanta BL5S Santa Rosa - Rev 1A...
                                          11-01-2024, 07:49 AM
                                        • sndestroy
                                          Toshiba Satellite P55-A5104SL - corrupted BIOS
                                          by sndestroy
                                          Hello all
                                          Model - Satellite P55-A5104SL
                                          Mainboard - VGSG MB Ver:2.1
                                          All flashing done w/CH341 adapter & EEPROM chips off board.
                                          PROBLEM:
                                          After updating from BIOS 1.70 to 1.90, it shows Toshiba logo and halts. I narrowed it down to a possibly corrupted BIOS. How do I know? There is no similar machine in the forums, so I tried a dump for another model with same mainboard (L50-A-19N) provided by @ala_borbe in this thread. Flashed this on both BIOS & ME_FW chips and the laptop came to life again! BUT, with these symptoms:
                                          05-09-2021, 12:20 AM
