Toshiba Satellite A300 display
  • dycc
    Vision
    • Nov 2011
    • 624
    • CΓ΄te d'Ivoire
    Re: Toshiba Satellite A300 display
    Originally posted by innocentforeign
    finally solve it .
    add 6x 330uf and 2x 470uf capacitors also change one capacitor inside CPU socket . now, if i press power button laptop start after 15 second and working good .delay 15 second in startup can create any problem in future
    or its ok ?
    i am so thank full all of you for help special sir Spidey,
    so many cap ;you have to find good one with low esr. only 3 or 4 470 will suffice.
    • rievax_60
      • May 2012
      • 897
      • australia
      finally solve it .
      or its ok ?
      Maybe you are using capacitors with not low enough ESR. You need to read more of the other thread to get a better understanding.
      • mangtomas
        • Jun 2014
        • 63
        • philippines
        is it possible to replace the nec tokin with 4 470uf tantalum caps?
        • mangtomas
          • Jun 2014
          • 63
          • philippines
          I've tried replacing the nec tokin with 4 330uf caps this is what happened, only one channel of ram is working. Can you please help? Thanks in advance
          • Chieftain
            • May 2016
            • 72
            • Greece
            This is not from CPU's capacitor's replacement... You are not lucky enough .. check all smd resistances pointed to your bad ram slot
            • lanovey
              SF314-41 BIOS without internal display
              by lanovey
              Hello there,
              I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
              I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
              06-13-2025, 02:38 AM
            • carlo64
              Toshiba Satellite P20 BIOS
              by carlo64
              Hi, I'm looking for a different bios than the 210 (bios-s-p20-210win.zip found with google) for this laptop
              as this version seems to cause me pci conflict with the wireless card after the first reboot.
              Can you help me?
              Thanks!!!
              Carlo
              detail:
              TOSHIBA
              MODEL NAME:Satellite P20
              MOFRL NO. PSP20E-4G50V-IT/SP20-842
              P4 3.00Ghz/2X256/80G42/17WT/DS/LM
              SERIAL NO. 84324385K
              I84324385KSSP20E-4G50VITD​...
              10-22-2024, 05:13 AM
            • ladharimohamed2
              Need bios toshiba satellite pro r50-b-15j
              by ladharimohamed2
              I need bios for toshiba satellite pro r50-b-15j motherboard faebsy2
              i have tried this :
              but no power
              and i tried this
              the laptop worked but asked for a password
              i have tried many with same motherboard name wich is FAEBSY2 A5A003954010 A but the laptop didnt turn on (no lights, no fan spinning)
              i have attached my original bios wich has been corrupted after a windows update (turn on but black screen)
              if any have the bios for the exact model name will be great "toshiba satellite pro r50-b-15j"...
              04-18-2024, 07:54 AM
              Toshiba Satellite A300 A300-14S Laptop Schematic
              Quanta BL5S Santa Rosa - Rev 1A...
              11-01-2024, 07:49 AM
            • sndestroy
              Toshiba Satellite P55-A5104SL - corrupted BIOS
              by sndestroy
              Hello all
              Model - Satellite P55-A5104SL
              Mainboard - VGSG MB Ver:2.1
              All flashing done w/CH341 adapter & EEPROM chips off board.
              PROBLEM:
              After updating from BIOS 1.70 to 1.90, it shows Toshiba logo and halts. I narrowed it down to a possibly corrupted BIOS. How do I know? There is no similar machine in the forums, so I tried a dump for another model with same mainboard (L50-A-19N) provided by @ala_borbe in this thread. Flashed this on both BIOS & ME_FW chips and the laptop came to life again! BUT, with these symptoms:
              05-09-2021, 12:20 AM
