Need help identifying component
  • Stefax2001
    • Nov 2021
    • 15
    • Serbia
    Hi, i need help identifying component on HP x360 440 G1 motherboard ( Rumble 17869-1)
  • mon2
    • Dec 2019
    • 14663
    Part number with 'X' are usually for Crystals / clock oscillators.
    From BV, confirmed the part is a crystal - since the power rail is not showing in the BV, the part is not an oscillator which will require a power supply.
    The pin # shows as 24 so most likely a 24 Mhz crystal but not sure of the physical size. It could be a 2x3mm SMD crystal. You can measure with a micrometer and share the dimensions.
    • NightcoreSenpai
      • Apr 2025
      • 14
      Mfg Code: XTAL-24MHZ-182-GP082.30006.0531 OSC-3225-4P-3H36
      someting like:
      https://www.digikey.de/en/products/d...-L-R-T/2637768
      • Stefax2001
        • Nov 2021
        • 15
        • Serbia
        Click image for larger version  Name:	x2301.png Views:	0 Size:	58.3 KB ID:	3618206
        Thank you for quick and detailed answer.
        Dimensions are 2.5x3.2mm.
        someting like:
        Thank you.
        • Stefax2001
          • Nov 2021
          • 15
          • Serbia
          Update, after cross referencing x360 440 G1 board with schematics and boardview of elitebook 840 G6 (Both being 8th gen/sharing same CPUs) i think i found the matching crystal,could someone confirm this?
          Link to schematic & boardview https://www.badcaps.net/forum/docume...itebook_840_g6
          • Stefax2001
            • Nov 2021
            • 15
            • Serbia
            Transplatation successful, i stole X4751 from dead EliteBook 840 G5 motherboard, x360 440 G1 now starts and enters bios. I still need to reassemble the laptop and check if it really works as intended.
            mon2 ​ and NightcoreSenpai, thank you.
            • jons
              Need help identifying crystal
              by jons
              Got VW Bosch ECU with rotted away crystal oscillator and can't find frequency for it, it drives Bosch 30302 chip for which there is also no any datasheet. Markings on it says
              453NDK9X.
              and there is nothing on internets about it that I can find....
              10-02-2024, 09:50 AM
            • pc_okay
              Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
              by pc_okay
              Hello friends,
              Its been a while, i wish you an happy new year 2025 !
              I have this laptop doesn't start, power light up a second when pluging USB-C charger.
              Laptop take 0.11A.
              All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
              I get no oscilation on XTAL 32.768 KHZ
              Battery is not charging but charging led is here.
              PCH heat at 30° approximatively. (with no heatsink)
              I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
              It's a 2 pins Crystal.
              01-13-2025, 09:26 AM
            • OakleyDAR
              Zotac GTX 1050 Ti Mini ZT-P10510A-10L Replacement Crystal
              by OakleyDAR
              HI,
              I'm looking to replace the 27MHz crystal on this board as it isn't generating the signal. I thought it would be easy to identify a suitable replacement as there are clear markings on the crystal, but it appears I was wrong as Google gives nothing. Bad photo attached, but it has X27.0000 and 16AP1 on the casing. It appears to be a 3225 package, but looking through suppliers there are lots of different things like capacitance, tolerance, active or passive, etc. that need to be considered. Could anyone help identify a suitable replacement please?
              Thanks....
              04-21-2024, 03:07 PM
            • Keshenatech1
              Question on microprocessor crystal oscillator circuit
              by Keshenatech1
              I'm troubleshooting a reel controller board for an IGT slot machine. The digital section seems to be dead. There is no USB communication, PC or utility program for flashing firmware do not see it but they do see good/working boards. I noticed the waveform on the crystal is very erratic/asymmetrical/glitchy on the bad one compared to the nice even waveform on a good board. My question is would this most likely be caused by a bad crystal or something gone bad in the circuit loading it down? I'm attaching a couple pictures of my scope probing the good and bad boads.
              02-26-2024, 11:05 AM
            • RetroComputingGrotto
              Need Help Identifying A Diode
              by RetroComputingGrotto
              I have an MSI 3PA1 monitor on my bench that wont power on. I have tested the 2 (what I believe to be Schottky Diodes) and both are shorted in both directions (a common faulty from what I can see on Google) but I'm not certain what the markings on the Diodes mean so I need some help in identifying which ones to order from Mouser please?
              I've done a search for 101C 5100C and all I can find are datasheets for 5100C which say they are 20-100V 5A Schottky Diodes but I'm not 100% sure if this is correct or not and what significance the 101C is.
              We...
              09-22-2025, 06:47 AM
