Need help identifying crystal
  • jons
    • Feb 2014
    • 59
    • Latvia
    Got VW Bosch ECU with rotted away crystal oscillator and can't find frequency for it, it drives Bosch 30302 chip for which there is also no any datasheet. Markings on it says
    453NDK9X.
    and there is nothing on internets about it that I can find.
  • truclacicr
    • Apr 2019
    • 352
    • australia
    453 = 45 x 10^3 kHz = 45 MHz ???
    FWIW, NDK is a manufacturer of automotive grade crystals.
    https://www.ndk.com/en/products/sear...B8%AF%EF%BC%89
    • richnormand
      • Sep 2024
      If you cannot find information on this xtal you might consider using a simple ring oscillator to see the frequency.
      Or a square wave signal generator and a scope to look at the ringing frequency.
      • harp
        • Jun 2022
        • 643
        • Planet Earth
        "453 = 45 x 10^3 kHz = 45 MHz ???" Guess not that type decoded acording attach... maybe to search datasheet of ic for what is connected to crystal...
        • R_J
          • Jun 2012
          • 9608
          Looks like it just broke away from the board, likely poor solder, you could try removing the board and reinstall and resolder it
          Look at the other crystal... 447NDK9X, I suspect they are custom numbers
          • richnormand
            • Sep 2024
            Is there enough contact left so you can solder a pigtail or probe the xtal? If so can you put it back in circuit? If not, can you contact it to make it oscillate in a test circuit?
            If you can determine the frequency a substitute could be found in the same form factor.
            I assume the microprocessor is also a house number? If not you could ballpark the frequency from the spec sheet.
            Was it corrosion or something else that happened? The board looks clean overall from your photo.
            Do you have access to a scope, spectrum analyser, signal generator?
            Can you protoboard a simple ring oscillator (TTL CMOS inverters) and such to get it going and measure the frequency?
            Knowing that would help to give you more info to reverse engineer the issue.
            Cheers and best of luck.
            • jons
              • Feb 2014
              • 59
              • Latvia
              Legs ar corroded off although otherwise board is quite clean. No scope fast enough unfortunately, I think it must be in tens of Mhz, and microprocessor is Bosch 30302 as I wrote so this also is dead end. Looks to me that most realistic way is to bodge some wires to it which I've done and ECU starts, car still not running but that to my mech. Not the most reliable repair to my liking but it's at least something.
              Thanks all for suggestions.
              • truclacicr
                • Apr 2019
                • 352
                • australia
                442NDK = 4MHz
                443NDK = 6MHz
                444NDK = 8MHz
                445NDK = 10MHz
                446NDK = 12MHz
                447NDK = 16MHz
                453NDK = 28MHz ??? (unless the "5" is not part of the arithmetic progression)
                Edit:
                NDK W-191-451 is a 26MHz crystal, so 453 looks like 30MHz ???
                • Keshenatech1
                  Question on microprocessor crystal oscillator circuit
                  by Keshenatech1
                  I'm troubleshooting a reel controller board for an IGT slot machine. The digital section seems to be dead. There is no USB communication, PC or utility program for flashing firmware do not see it but they do see good/working boards. I noticed the waveform on the crystal is very erratic/asymmetrical/glitchy on the bad one compared to the nice even waveform on a good board. My question is would this most likely be caused by a bad crystal or something gone bad in the circuit loading it down? I'm attaching a couple pictures of my scope probing the good and bad boads.
                  02-26-2024, 11:05 AM
                • olane
                  Steam Deck Crystal Oscillator replacement part
                  by olane
                  Hi just wondering if anyone knew the part ID for the crystal Oscillator on the Steam Deck i've attached an image of the broken part on my board.
                  Thanks...
                  02-02-2024, 12:56 PM
                • pc_okay
                  Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
                  by pc_okay
                  Hello friends,
                  Its been a while, i wish you an happy new year 2025 !
                  I have this laptop doesn't start, power light up a second when pluging USB-C charger.
                  Laptop take 0.11A.
                  All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
                  I get no oscilation on XTAL 32.768 KHZ
                  Battery is not charging but charging led is here.
                  PCH heat at 30° approximatively. (with no heatsink)
                  I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
                  It's a 2 pins Crystal.
                  01-13-2025, 09:26 AM
                • Stefax2001
                  Need help identifying component
                  by Stefax2001
                  Hi, i need help identifying component on HP x360 440 G1 motherboard ( Rumble 17869-1)...
                  04-18-2025, 02:24 PM
                • Petr0x
                  Bosch 12V and 18V chargers modification
                  by Petr0x
                  Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                  You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                  Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                  05-24-2024, 01:00 PM
