Macbook M1s exclamation mark not seen in DFU
  • sjsul
    • Dec 2021
    • China
    Hi colleagues,
    I have a situation with 2 Macbooks M1, 1x A2337 and 1x A2338. I will post below the symptoms and what I have tried until now
    - They both power on and display the exclamation mark 1 second after displaying the Apple Logo
    - They both try to enter Recovery but after restart they loop in the step above, showing the exclamation mark
    - They both enter DFU but are not recognized by the other computer. Also tried force DFU, bot have voltage on SOC_DFU_STATUS. Still not found by other computer in Apple Configurator or Finder, used more cables, TBT3 and TBT4
    - Both USB ports on both laptops are stable, drawing 20.6v and 0.3a with no battery connected
    - On the A2337 tried replacing the Thunderbolt Controller UF000 and also PMIC U8100. The problem remains the same.
  • icfix2499
    Ic-notebook
    • Nov 2021
    • 6
    • thailand
    BIOS is bad. Update BIOS and restore again.​
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
      🛠 Original Issue
      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • mkdj
      MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
      by mkdj
      About me, my goal and the equipment I (don't) have:
      I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
      About my issue and my goal:
      A friend of mine has a MacBook Air M1 A2337 that does not...
      04-03-2025, 08:28 AM
    • Adogabriel100
      where to get trusted CD3217. Problem with A2337 Macbook Air
      by Adogabriel100
      Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
      The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
      09-06-2024, 12:06 PM
    • Skrndelj
      Apple Macbook Air M1 A2337 Trackpad problem
      by Skrndelj
      Hello all,
      I am repairing a Macbook A2337 and i have a problem
      The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
      When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
      I inspected the whole board and everything seems fine.
      Can anyone help me as i didn't fiddle with trackpad...
      06-11-2024, 04:26 AM
    • Patrick501
      Macbook Air A2337 dead at 5V/0,00A
      by Patrick501
      Hey,
      I'm working on a MacBook Air M1. I'm pretty sure the U8100 is not working correctly. But I never had to change it before, so I wanna ask anyone of you guys to confirm (or not confirm) my thoughts on it.
      USB Tester: 5V / 0,00A
      PPBUS_AON: 12,3 V
      PP5v_S2: 0 V no short
      PP3v3_S2_UPC: 0 V no short
      PP1v25_S2: 0 V no short
      PPDCIN_AON_CHGR_R: 5 V
      no enable signals for the S2 rails by the U8100
      both CR3217 (UF400, UF500), are supplied by 5V (Fuses FF200 and FF201)
      PP3v3_UPC0_LDO: 0 V, 0,5V diode mode to gnd
      PP1v5_UPC0_LDO_CORE:...
      11-29-2024, 02:47 PM
