HP 15s-FQ Series / MB: DA0P5HMB8J0 REV: J / Loop turns on and off without video.
  • gabrielA7
    • Jan 2022
    • 13
    • brasil
    When I turn it on, the white LED flashes and then turns off, and it stays like this.
    We have 3 and 5V S5 as soon as I start it, then the voltages drop because we don't have the MAIN_ON that originates from IT5570 pin 33.
    We don't have a short in the sources.
    I re-recorded 2 BIOSes here on the site, which apparently are OK.
    Now I would go for the EC IT5570 BIOS, but I couldn't find it anywhere.
    What else could I check to make this MAIN_ON pulse appear?​
  • pc_okay
    • May 2022
    • 241
    • FRANCE
    Hello friend,
    Do you have VCCDSW (coming from +3VPCU) ?
    SLP_S5# , 4 and 3 ?
    • burbutsalos
      55" QLED QE55Q60T Turns on after 1 minute the picture goes bad and get in boot loop
      by burbutsalos
      Hello ,
      The issue with this set is that it turn on just fine and after a minute or so the picture shows either vertical lines or turns half black and from that point on starts a boot loop.
      If a let the unit to cool down for a minute the same pattern starts again. i had exactly the same mainboard as a spare and replaced it but nothing changed.
      Any ideas what to check?...
      12-12-2023, 06:06 AM
    • Takeatry
      Yet another Samsung QLED Boot Loop
      by Takeatry
      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
      10-04-2024, 02:57 PM
    • Stephen
      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
      by Stephen
      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
      03-15-2024, 09:37 AM
    • www
      LG L192WS-BN backlight turns off after 1 second
      by www
      I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
      I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
      03-24-2024, 05:26 PM
    • zklgfs
      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
      by zklgfs
      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
      08-11-2025, 02:14 PM
