macbook pro "battery assistance required"
This topic has been answered.
  • Grandoni Manuel
    • May 2024
    • 12
    • San Marino
    Hello to all Masters , so i've two macbok pro with this problem, come to chane battery bcs have essage about assistance , but also after changed the battery say "battery assistance required"!!!
    i change also new flat and try other battery but same issue on this 2 macbook pro !
    where i can check and what please ? thanks
  • Answer selected by Grandoni Manuel at 04-11-2025, 12:51 AM.
    mon2
    • 14672
    Which exact macbook? Share the bottom side laser markings with the 'A***' model number.
    • mon2
      • 14672
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        try to do a discharge and fully charge. after it's fully charget let it still plugged for some 2 hours more. see if it fix the problem. also cdo a smc reset or pram.
        • Grandoni Manuel
          • May 2024
          • 12
          • San Marino
          hello,ok i'll try to do this thanks !
          the model now here i've A1989 and also have one A1708
          UPDATE
          i just try to reset smC and also pram exc.. but nothing have always message "battery assistance required"
          i try also to reinstall ios but same !!
          • mon2
            • 14672
            Carefully measure the voltage to ground of each pin on the battery connector. Post each measurement.
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • reformatt
              A2337 not working with flat battery
              by reformatt
              Looking for some advice on a 820-02016 board as I don't have much experience with these M1 machines. Learning the nuances of them as I go.
              So the history of this machine was it had been in a bag where a bottle of water leaked. Presented as dead about a month ago, corrosion was mainly around the battery connector and it's sub-PCB. Some corrosion was noted on the board around UC300, CC325, CW1C7, CW1C8. That was it really.
              Now without battery connected, USB-C will stay at 5V and cycle between 0 and 120ma. PPBUS_AON is cycling between 0 to 12.3V. If battery is connected,...
              10-12-2023, 04:36 PM
            • gboone
              820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
              by gboone
              Hi, I was given this laptop by my uncle who said:
              • It would occasionally shutdown if not plugged in
              • battery had been replaced
              • touchbar would "strobe"
              I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
              After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
              BUT
              When powered off, it would at some point have a...
              01-27-2025, 09:12 AM
            • mferna14
              MacBook Air A2681 battery problem after Screen Replacement
              by mferna14
              Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
              12-06-2024, 08:10 PM
            • mkdj
              by mkdj
              Mark and model: ASUS X571
              Tests already made:
              - I have removed...
              07-14-2025, 09:16 AM
