MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
  • EpicFix
    • Aug 2024
    • 43
    • Trinidad & Tobago
    Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
  • mon2
    • Dec 2019
    • 14147
    Remove all power. No battery. Meter in resistance mode. Measure the resistance to ground of PPBUS_G3H @ fuse F7000 (check both sides). What is the resistance in ohms?
    • EpicFix
      • Aug 2024
      • 43
      • Trinidad & Tobago
      Checked the fuse on both sides:
      (2) PPBUS_G3H 6.4 MOhms
      (1) PPVBAT_G3H_CHGR_REG 5.8 MOhms
      • mon2
        • Dec 2019
        • 14147
        No shorts here. What is the voltage to ground on PPBUS_G3H?
        • EpicFix
          • Aug 2024
          • 43
          • Trinidad & Tobago
          Measured at R6905, it's 4.4 MOhms
          • mon2
            • Dec 2019
            • 14147
            No. Asking about the voltage here. Meter in DC volts scale of 20v or higher. Red meter probe on PPBUS_G3H. Black meter probe to ground. What is the voltage? Is it stable?
            • EpicFix
              • Aug 2024
              • 43
              • Trinidad & Tobago
              0v..... checked @ R3351 and F5400
              • mon2
                • Dec 2019
                • 14147
                What is the voltage to ground on D6905? Test each pin. Post each measurement.
                • EpicFix
                  • Aug 2024
                  • 43
                  • Trinidad & Tobago
                  With charger plugged in to the looping port
                  PIN 1 = 0.086V
                  PIN 2 = 1.7V then 5.02V cycling
                  PIN 3 = 4.7V then 1.7V then 2.4V cycling
                  On the constant port
                  PIN 1 = 0.094V
                  PIN 2 = 0.9V
                  PIN 3 = 0.8V
                  • mon2
                    • Dec 2019
                    • 14147
                    Remove all power. Meter in resistance mode.
                    What is the resistance to ground of PPDCIN_G3H_CHGR in ohms?
                    • EpicFix
                      • Aug 2024
                      • 43
                      • Trinidad & Tobago
                      5.7 MOhms @ R6906
                      • EpicFix
                        • Aug 2024
                        • 43
                        • Trinidad & Tobago
                        I also checked these following a CD3215 boot sequence guide and they are all present:
                        PP3V3_UPC_XB_LDO
                        PP1V8_UPC_XB_LDOD
                        PP1V1_UPC_XB_LDO_BMC
                        PPDCIN_G3H
                        USBC_XB_CC1
                        USBC_XB_CC2
                        • mon2
                          • Dec 2019
                          • 14147
                          Meter in DIODE mode. No power to the board.
                          Confirm that the dual diode @ D6905 is ok. Red meter probe on pin # 1; black meter probe on pin #3. Meter should conduct.
                          Reverse the meter leads and the meter should block.
                          Repeat to test pins #2 and pin #3 in the same way. We want to check that D6905 is leaking and allowing for a reverse voltage to travel through the part.
                          Also, what is the voltage to ground of PPDCIN_G3H? Is it stable?
                          • EpicFix
                            • Aug 2024
                            • 43
                            • Trinidad & Tobago
                            Diode is testing good
                            • mon2
                              • Dec 2019
                              • 14147
                              Also, what is the voltage to ground of PPDCIN_G3H? Is it stable?​
                              • EpicFix
                                • Aug 2024
                                • 43
                                • Trinidad & Tobago
                                4.5V constant on the stable port
                                5V cycling to 2.2V on the looping port
                                • mon2
                                  • Dec 2019
                                  • 14147
                                  Which port on the board is cycling? Share the index name for the part.
                                  Even 4v5 is too low since the USB-C (official) will supply 5v or slightly higher. Would have a thermal camera?
                                  • EpicFix
                                    • Aug 2024
                                    • 43
                                    • Trinidad & Tobago
                                    Highlighted is the looping port. Yes I have a thermal camera and voltage injection tool / short killer. Point me in the right direction.
                                    • mon2
                                      • Dec 2019
                                      • 14147
                                      To me, there is a shorted part onboard in this region since the VBUS is not the text book 5v for each and every permutation of the USB-C port.
                                      Revising...I am going cross-eyed and referenced the wrong schematic. Will review this later and update with suggestion by tomorrow. Late at the office now.
                                      Suggest to investigate the VBUS of each of these USB-C ports. Check their resistance to ground. One of these is with a shorted part onboard since the 5v from PD adapter is sinking to 4v5 which is too low.
                                      • EpicFix
                                        • Aug 2024
                                        • 43
                                        • Trinidad & Tobago
                                        Both are 0.68KOhms checked @ F3000 and F3010 respectively
                                        • Bmet
                                          MacBook Pro 13 inch A2238 M2 stuck on 5V
                                          by Bmet
                                          I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                                          04-02-2025, 05:02 PM
                                        • DATATECH85
                                          Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                                          by DATATECH85
                                          I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                                          The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                                          I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                                          However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                                          Here are the values...
                                          07-24-2024, 06:34 AM
                                        • martyjelen
                                          Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
                                          by martyjelen
                                          Hello, I have this Macbook A2141. It stuck at 5V / 0,075A. I measured all 4 ports, all the same. PPBUS_G3H is present but only 12,3V. Should be 12,6V ? according to this article : https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
                                          PP3v3_G3H_RTC_X is present - 3,3V
                                          PP3v3_G3H_SOCPMU is present - 3,3V
                                          ​What else should I check?
                                          Thank you for your help.
                                          05-05-2025, 01:34 AM
                                        • duwane
                                          MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                                          by duwane
                                          Hi All.
                                          I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                                          Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                                          After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                                          Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                                          10-17-2023, 07:48 PM
                                        • 24gsm
                                          MacBook Pro A1708 install macos fail
                                          by 24gsm
                                          hi to all
                                          i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                                          after enter to recovery and format hdd 1to .
                                          after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                                          can help please
                                          Serial Number: FVFXP0U0HV2J
                                          Config Code: HV2J
                                          Find My Mac: OFF
                                          04-16-2025, 03:57 AM
