compaq cq20 no power
  • sasser
    • Dec 2012
    • 364
    • Malaysia
    hye all masta and sifoo i got another compaq problem. i think is mosfet is failure but let discuss what need to do. i attach shcematic for this model. i suspect Q10 is faulty because on pin 1234 i got all 19v but no volt on 5678.
    mosfet Q10 TPC8121
    pin 1 19.41v
    pin 2 19.41v
    pin 3 19.41v
    pin 4 18.99v
    pin5-8 no voltage. near this mosfet u1 the power is ok. and u13 all pin no power
    tps51120 no vin at pin 22.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3588
    • slovakia
    Re: compaq cq20 no power
    yep, its bad.
    • dj_ricoh
      • 2073
      no its not!
      you need to be 100% sure the gate its ok.
      A MOSFET may be thought of as a variable resistor, where the Gate-Source voltage difference can control the Drain-Source Resistance. When there is no applying voltage between the Gate-Source , the Drain-Source resistance is very high, which is almost like a open circuit, so no current may flow through the Drain-Source. When Gate-Source potential difference is applied, the Drain-Source resistance is reduced, and there will be current flowing through Drain-Source, which is now a open circuit.
      You need to take it out test it properly
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3588
        • slovakia
        wanna bet on it?
        • atsio
          • Oct 2013
          • 819
          • Greece
          Pin 4 should be low. Check limit signal.
          • dj_ricoh
            • 2073
            Its a P-Channel Mosfet.
            It has the VGS on max+/- 25V and its on pin 4
            he needs to take it out and test it in diode mode or see if it got short on pads.
            • aanan
              • 222
              • India
              check ADP-EN# point.
              • fddizon
                • Sep 2011
                • 555
                • Philippines
                atsio is correct. at least 0 to 5 volts, p channel will conduct correctly.
                check gate protection circuit
                cant find the said part from the supplied schematic. all fets are labeled Q10xx
                4 digit numeric
                • sasser
                  • Dec 2012
                  • 364
                  • Malaysia
                  atsio howto check limit signal im sorry im still new in electronic field.
                  4 digit numeric
                  yes i found label on pcb is Q10,q11,q13. i try read the mosfet q10 the result is same. pin 1-4 around 19.41v then no volt on 5-8.
                  • sasser
                    • Dec 2012
                    • 364
                    • Malaysia
                    i will post the result today. but if i found no shorted howto know got short on pads.
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      Page 14 of the schematic, has all the Over current protection circuitry. Limit signal is the input.
                      • dj_ricoh
                        • 2073
                        1 --|__ |-- 5
                        2 --|__ |-- 6
                        3 --|__ |-- 7
                        4 --|__ |-- 8
                        just put the probe on 1,2 or 3 and then the other on 5,6,7 or 8
                        select continuity and if it beeps that`s bad
                        • sasser
                          • Dec 2012
                          • 364
                          • Malaysia
                          i have checked the mosfet q10. no shorted i found
                          • dj_ricoh
                            • 2073
                            on fet or pads?
                            • sasser
                              • Dec 2012
                              • 364
                              • Malaysia
                              on fet . i just test mosfet. on pad howto detemine there hav shorted.
                              on page system power 3v 5v i measure Q33 Q34 Q35 no 5volt there. tps51120 also on pin 22(vin) no volt
                              • tzoupkas
                                • Jun 2014
                                • 14
                                • Greece
                                hello my friend I would change the U1 LM393 for start as I don't get the correct voltage at gate pin. Do that if possible and we will see what to do next.
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3588
                                  • slovakia
                                  just chceck function of q10 with multimeter and replace if failed
                                  • sasser
                                    • Dec 2012
                                    • 364
                                    • Malaysia
                                    i try later friend coz need to find same code LM393 on another scrap board.
                                    will update after change .im measure no volt on LM393
                                    already check like before the volt on gate still 18.88v also pull out from board and do manual checked and im sure the fet is ok. but why gate got the 18.88v still mysterious
                                    • tzoupkas
                                      • Jun 2014
                                      • 14
                                      • Greece
                                      also U18 might me burned, when you will change the U1 touch with your finger the U18 for overheating.
                                      • sasser
                                        • Dec 2012
                                        • 364
                                        • Malaysia
                                        hye friend u are right. i got clue from that. when i checked again the LM393 (u1) small damage i see. like burn sign. then i change with another lm393. now standby current got 0.0489. before this 0.0030A.
                                        now i touch what overheat from area U6. will post the result thanks so much all friend to help me here.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Thomas Smith
                                          Asus Tuf gaming fx506l no power, mosfet does not open
                                          by Thomas Smith
                                          Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
                                          Initial Symptoms:
                                          • The laptop has no power at all (no LEDs, no fan spin).
                                          • No 3.3V or 5V present on the board.
                                          • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
                                          Power Rail Checks:
                                          1. Charger input (FETs PKCH2BB)
                                            • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
                                          2. BQ24780S Charger IC:
                                            • VCC and ACDET are present.
                                            • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                                            • Shunt resistor has 10Ω to ground.
                                          03-30-2025, 03:38 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
