compaq cq20 no power
    Re: compaq cq20 no power
    After checked caps and resistor around kbc i found 1 resistor faulty and replace with another on and standby power coming 1.300a. Intel southbrigde very hot. Maybe need to replce
      yes finally i solved this problem. CQ20 is normal if stanby power without press button only 0.0203 then when press button motherboard got 1.200-1.300A. for power on the motherboard checked fan connected or not. when connected with CPU fan the laptop is straightly display . maybe sensor detected no connected fan and the current cut off.
      now my laptop can turn on with normal display.
      before this i try change nec/tokin with tantalum 330uf .after check positif pad is 1.22v. actually its normal when got 1.22v on nec. no need to replace with tantalum 330uf.
      thanks all masta.
        Nice!
        what did you change only that resistor? what value was it?
          Dj ricoh Both side Got 3.12v when adapter on.
            dear all forumers
            i have trouble with my compaq cq20.. i can't use my onboard keyboard when i try to entering my bios even in my win7 it can't work. than i try use the external keybord but it seem's like my usb port is also not working.
            anybody... can u help me to figure it out ???
