MacBook Pro A2251 - 820-01949-A not charging
  • MikoMiko
    • Mar 2025
    Hello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where the audio jack is located, not going further than 2cm into the logicboard. I took a visual inspection of the board and could not see any blown capacitor, I measured a lot of the caps and none were shorted. When the cable is plugged in I can measure the 12.4V, without the cable none, probably because the battery is empty. I bought a thermal camera and a USB Meter to get more information for the diagnosis. I could measure 3.3v across some places. I will look deeper into the schematic to get an idea of the problem but need to get a second computer for that. Do you guys have an idea where the problem comes from? Which lines should I measure to get a better understanding of what's wrong?
    Due to work I can continue diagnosing it next week, and then I will have access to a microscope and the thermal camera and the meter should have arrived until this point.
    I will update you guys when I find out more.
  • FriedFred
    • May 2024
    • 141
    Maybe the battery itself is bricked.
    • reformatt
      • Feb 2020
      • 1534
      Are you getting 20V negotiated on USB-C and what is the current flow? Check battery flex cable for corrosion etc, SMBUS lines to battery etc. Go to System Report/Power, is battery data reported? Service Recommended etc?
      MAC OS doesn't report charging till about 1 minute after being plugged in, even though battery is charging.
      • Stephen
        A2251 MacBook Pro 13" Charging issue
        by Stephen
        Hello old friends,
        I have a customer that came in with a A2251 MacBook Pro 13" DFU mode revive works, DFU works, battery is in Normal state checking the computer, however it only charges up to 65% then it stops and charges again and stops and charges again every 5 seconds. It disconnects from the cable (we are using an OEM 61W and OEM cable) question is being that the Battery is in Normal state (Not service recommend or replace now or soon) could this be a faulty board issue or? Would like your expertise, I am leaning towards replacing the battery to see if it persists but before...
        06-28-2024, 02:55 PM
      • drlarsen
        MacBook Air M1 A2337 battery/charging issue
        by drlarsen
        Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
        I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
        On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
        After some hours, the battery status did not improve. Restore via DFU did not help.
        I connected the power adapter to a Kill-a-Watt...
        07-17-2025, 02:35 PM
      • robka
        MacBook Pro 2018 - A1990 Dead - not charging - only 5V
        by robka
        my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
        I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
        The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
        After that the Macbook was dead. It isn't charging anymore.
        The USB-C Port where the charger was plugged is burned. Also The Cable and the...
        03-02-2024, 02:58 PM
      • Gueric
        Macbook Pro M1 (A2338) 820-02020 not charging.
        by Gueric
        I returned home from college. My MacBook battery was flat. Plugged it in. Nothing. Won’t boot. Waited for an hour. Nothing.
        When plugging the charger : 20v at 0.02 amps.
        pressing any key will make the « low battery » icon show up. Then switch to 5v and 420mA constant. Trackpad clicks, keyboard works.
        Decided to put the board into another M1 body with a charged battery, it’s booting perfect, still 5v and 420mA tho, and battery is not charging.
        I diode moded every pin of U5200 and they’re all fine. I know very little about Apple silicon machines...
        07-23-2025, 01:54 PM
      • tyler_jones8209
        2021 M1 MacBook Pro (A2442/820-02098-A) Stopped Charging on All Ports
        by tyler_jones8209
        So my friends A2442 MacBook Pro stopped charging one day and hasn’t worked since. It wasn’t like an immediate shut off, like it worked until the battery died but now she can’t charge it so idk what to do with it.
        I don’t have an ammeter (yet it’s coming soon) so idk if it’s doing anything funky with current or voltage but I know it doesn’t charge on ANY of the ports.
        I took it down to the motherboard hoping to see an obviously bad component but everything looks good.
        I don’t have much experience with laptops, only consoles and controllers...
        10-28-2025, 04:54 PM
