A2251 MacBook Pro 13" Charging issue
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Hello old friends,
    I have a customer that came in with a A2251 MacBook Pro 13" DFU mode revive works, DFU works, battery is in Normal state checking the computer, however it only charges up to 65% then it stops and charges again and stops and charges again every 5 seconds. It disconnects from the cable (we are using an OEM 61W and OEM cable) question is being that the Battery is in Normal state (Not service recommend or replace now or soon) could this be a faulty board issue or? Would like your expertise, I am leaning towards replacing the battery to see if it persists but before we do that I need to confirm if it is INDEED that battery or a board issue, hoping it is just a faulty battery, the battery has 13 cycles.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • 14356
    I would,
    1) test with a beefier power supply @ 100W (Anker or another known good adapter brand - check Amazon and their reviews) - be sure to pair with a 100W rated type C cable with PD support. By specification, if marked at 100W or more, there will be an e-marker chip inside of the Type C cable.
    2) then test with another battery (Amazon so you can return it if not required).
    PS: Is the battery the Apple (OEM) original or another brand/replacement?
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Originally posted by mon2
      I would,
      Could you link me to the Amazon PD Cable you use? I see the 100w ANKER, have it in the cart, but the cable I am curious about? Could you link me to the ones you use on AMAZON? I am always opposed to not using Genuine but of course for testing purposes yes. Also the Battery is an OEM Original Battery.
      Nevermind I found the cable
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        I would,
        Just received my Anker 100w and the PD cable as well, computer is charging up currently without disconnecting. What would be the cause of this if the computer is charging normally? The original 61 oem brick and oem cable is not charging his computer up for a certain amount of time then disconnects and reconnects to charge. Any reason this is? Battery is still in normal operation. Any feedback would be appreciated.
        Battery is still climbing in charge, so something is off? Could it be the charger?
        I am most likely going to rule the battery is faulty. EVEN THOUGH, it states it is in Normal operation. Which blows my mind because no doubt Service Recommended I would know right off the bat the battery is bad, however considering its at 68% and not climbing but its still charging is telling me the battery is faulty?
        Update: The battery charging is disconnecting and reconnecting with the Anker 100w and PD cable. Ruling this is a battery issue but need a second opinion
        sigpic
        • mon2
          • 14356
          How old is this laptop?
          Based on the # of charge cycles, the battery 'should' be ok. Can you try to get Apple to cover the battery under warranty or is this box out of warranty? They will probably wash their hands of any service since the laptop has been opened.
          I would certainly test with another battery if the battery gauge is stuck during the charging process. Be sure to also check the voltage to ground of each and every pin on the battery connector. This is to confirm that the SMBUS SDA & SCL lines are not defective (due to ESD transients which will take out the ESD diodes which will nuke the communication lines to the SMBUS host controller).
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 667
            There is no Apple warranty on this particular one, since it was way past over due. This is a customer purchase and it's a first time seeing the battery do this, it charges fine then stops charging up to 68%. I will swap out the battery first since we have some spares, for all we know this battery has a defective part on it, not worth fighting it if we have a few spares.
            sigpic
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 667
              Upon inspection, we opened the case and noticed the new battery had a swollen cell, it is odd that this did not trigger the service recommend message. We swapped the battery out and all is well.
              sigpic
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                🛠 Original Issue
                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • pcbmaniac
                MacBook A1278 (3115) No PPBUS_G3H Issue
                by pcbmaniac
                Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                1. U7000 Measurements:
                  • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                2. Resistors:
                  • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                • If I also decide to replace the SMC, do I need to order it pre-programmed,
                12-02-2024, 04:12 PM
              • sofles
                Macbook a1707 2017 model 820-00928 GPU issue
                by sofles
                Hello there
                I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                11-21-2024, 05:25 AM
              • Stephen
                A2141 MacBook Pro 16" lid sensor issue.
                by Stephen
                Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
                11-01-2024, 03:45 PM
              • Gueric
                MacBook Pro 2019 820-01700 Speaker amp issue.
                by Gueric
                I have this MacBook Pro on my bench that I have already fixed, hard short on a SSD rail, but it also has another issue. the right speaker sound is either earrape, muffled or absent. Left one works perfect. I have tried replacing it, nothing changed so I'm pretty sure the issue is either motherboard related or maybe software but I doubt that.
                I don't how to troubleshoot speakers. Any help would be very much appreciated.
                A refurbisher and a repair shop have already been inside the laptop but I'm pretty sure none of them tried to do any soldering on the board.
                05-19-2025, 03:08 AM
