820-2915 not charging
  • wnt2fx
    • May 2021
    • 25
    Hi guys, have a 2011 15 inch here with not yet failed radeon. All ooks clean, no visible damage. It only boots with battery attached. First I had no green light and measured weird voltages at u6900 / u6901. When I returned a day later bc acok and 1 wire seemed fine and had green light but still no fan spin. If I attach the batteryafter magsafe it immediatel boots. Yes, real 85w original charger Should I go through the initial power rails on magsafe only ? I was thinking of just replacing the ISL but then I thought: no guessing, understand the problem right first. The current sensing in and out resistors are good as r6990 and f6905 are. My brain is so out of routine. I did not really work for almost 2 years of sicknes. I thought I ask for a hint here before I go on getting my slow brain back into logical thinking haha. best regards
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • Thomasraud
    Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
    by Thomasraud
    i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
    QUOTED
    -It works on charger (without battery connected-only charger)
    -It works on battery (without charger connected-only battery)
    -& it also works when plugged in battery & charger, but it's not charging the battery
    //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
    and..
    QUOTE
    The IC cannot maintain the input current level
    06-28-2022, 06:47 PM
  • Scoff
    HP Probook 470 G4 - Power and Charging Problem
    by Scoff
    Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
    Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
    07-03-2023, 09:28 AM
  • SluggerB
    Help with trying to fix phone that is not charging (Pics inside)
    by SluggerB
    I have two TCL A30 phones.
    Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
    New Phone: Works fine, bought as a donor board to try and repair Old Phone
    My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
    08-12-2024, 08:11 AM
  • macdude101
    A1989 (820-00850) Battery not charging, boots only from charger
    by macdude101
    Got a MacBook Pro 2019 (A1989) (820-00850) that boots fine so long as it's powered from the power adapter.
    On boot into macOS the battery shows as not charging, and needs servicing. Laptop runs slow, benchmarks are all 50% of expected.
    Diagnostics reports a battery issue (PPT006) but also a potential SMC issue (PFM006).
    Battery has 46 cycles, though went un-used for 2 or 3 years.
    Trying to determine if I should go ahead and replace the battery in the hopes that's causing all the issues or if actually it's the other way around and the...
    02-22-2023, 03:40 PM
